1591XXCFLGY
1591XXCFLGY
    HAMMONDMANUFACTURING
    BOX ABS GRAY 4.78"L X 2.64"W
1591XXCFLGY 数据手册
145.16 [5.72] 36.00 [1.42] INSIDE HEIGHT 121.44 [4.78] 107.00 [4.21] B 2.00 [.08] WALL THICKNESS 66.94 [2.64] 56.49 [2.22] A A B TOP VIEW 6.50 [.26] LID HEIGHT 6.10 [.24] 52.50 [2.07] 40.00 [1.57] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 37.25 [1.47] BOX HEIGHT 4.34 [.17] 114.50 [4.51] 99.00 [3.90] 44.50 [1.75] 60.50 [2.38] 115.15 [4.53] INSIDE LENGTH 4.50 [.18] 60.65 [2.39] INSIDE WIDTH MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE SECTION A-A SIDE VIEW 39.50 [1.56] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. R3.50 [.14] 84.50 [3.33] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE 3.50 Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m [.14] 118.98 [4.68] 4X 3.50 THRU  6.00 X 82° 4X 5.00 THRU  9.00 X 82° PART NUMBERS 64.48 [2.54] 5.00 39.50 [1.56] [.20] 60.07 [2.36] 84.50 [3.33] 5.00 11.50 [.45] 84.50 [3.33] INSIDE BOX M3-0.5 BRASS INSERTS INSTALLED BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW [.20] 44.40 [1.75] 39.50 [1.56] 3.00 [.12] 114.57 [4.51] 133.40 [5.25] INSIDE LID Dimensions: mm [inches] 1591XXCFL Enclosure Black Textured Enclosure 1591XXCFLBK Gray Textured Enclosure 1591XXCFLGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] 1591XXCFL www.hammondmfg.com ®
1591XXCFLGY 价格&库存
很抱歉,暂时无法提供与“1591XXCFLGY”相匹配的价格&库存,您可以联系我们找货
1591XXCFLGY
  • 1+100.751251+13.07915
  • 5+84.659165+10.99014
  • 10+78.6134410+10.20531
  • 25+71.3234625+9.25895
  • 50+66.2971850+8.60645
  • 100+61.64914100+8.00306
  • 250+56.03026250+7.27364
  • 500+53.78891500+6.98268
库存:1
