1593TTBU
1593TTBU
    HAMMONDMANUFACTURING
    BOX ABS TRN BLUE 4.41"L X 2.62"W
1593TTBU 数据手册
66.50 [2.62] B 3.50 [.14] 112.00 [4.41] A A 1.00 [.04] INLAY DEPTH 1.50 [.06] 4.50 [.18] 100.00 [3.94] 14.80 [.58] 69.93 [2.75] INSIDE HEIGHT INSIDE LENGTH 21.00 [.83] B 55.00 [2.17] SECTION B-B SIDE VIEW INLAY WIDTH TOP VIEW 57.25 [2.25] 13.80 [.54] 2.63 [.10] 2.25 [.09] INLAY LENGTH DETAIL C ACCEPTS #4 SELF-TAPPING SCREW C Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 60.79 [2.39] INSIDE WIDTH 55.35 [2.18] 1.40 [.06] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Enclosure molded from GP ABS (UL94-HB) plastic. Purchased assembly includes top and bottom cover, 1 plastic flat panel for front, battery door and 4 cover screws. Recommended Cover Screw Torque - 57lbf-in ( 40cN-m) 57.89 [2.28] SECTION A-A END VIEW END VIEW 8.50 [.33] 23.43 [.92] INSIDE TOP 1593 1593T Regular Enclosure Black Enclosure Grey Enclosure Translucent Blue Enclosure 50.67 [1.99] 1593TBK 1593TGY 1593TTBU ACCESSORIES 60.40 [2.38] 33.27 [1.31] 68.62 [2.70] 53.63 [2.11] 60.40 [2.38] 6.86 [.27] Cover Screws #4 X 5/8" Self-Tapping (100 Pkg) 7.85 [.31] P.C. Board Screws #4 X 1/4" Self-Tapping Nylon Belt Clip 1-AAA Battery Holder (Single) 2-AAA Battery Holder (Single) 4.90 51.10 [2.01] [.19] 5.85 Black 50.20 [1.98] 9.58 [.38] 28.00 [1.10] 15.57 [.61] P.C. BOARD (NOT SUPPLIED) 43.43 [1.71] 1593T STD FLAT PANEL (SINGLE PANEL) 59.14 [2.33] Grey Translucent Blue Infrared 1593MS100 (Silver) 1593MS100BK (Black) 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) 1599CLIP (Black) 1599CLIPGY (Grey) BH1AAAW BH2AAAW 1593SLBK‐BULK 1593SLGY‐BULK 1593SLTBU‐BULK 1593SIR10 [.23] 3.00 [.12] 8.13 [.32] INSIDE BOTTOM ACCEPTS #4 SELF-TAPPING SCREW 13.33 [.52] 43.25 [1.70] ® 3.20 [.13] Dimensions: mm [inches] 1593T www.hammondmfg.com
1593TTBU
物料型号: 1593T
器件简介: 该文档描述的是Hammond Manufacturing公司生产的1593T系列的塑料外壳,由GP ABS材料制成,符合UL94-HB标准。外壳包括顶部和底部盖板,以及用于前电池门的1个塑料挡板和4个盖子螺丝。
引脚分配: 文档中没有提供详细的引脚分配信息。
参数特性: 外壳的尺寸参数包括长度100.00mm (3.94英寸),宽度69.93mm (2.75英寸),高度55.00mm (2.17英寸)。内部尺寸包括内部长度60.79mm (2.39英寸),内部宽度57.25mm (2.25英寸),内部高度50.67mm (1.99英寸)。
功能详解: 外壳可以进行工厂修改(铣削、钻孔、打印等)。有关报价,请联系工厂。提供STEP或IGES格式的实体模型。请注意,我们的产品上的部件编号和文字放置/方向可能会更改,不建议将其用作修改的定位参考。
应用信息: 适用于需要塑料外壳的电子设备,如电池盒、控制面板等。
封装信息: 提供黑色、灰色和半透明蓝色外壳。配件包括#4×5/8英寸自攻螺丝(100包装),#4×1/4英寸自攻螺丝(50包装或100包装),尼龙腰带夹,1-AAA电池座(单个)和2-AAA电池座(单个)。
1593TTBU 价格&库存
很抱歉,暂时无法提供与“1593TTBU”相匹配的价格&库存,您可以联系我们找货
1593TTBU
  • 1+102.922431+13.33206
  • 5+86.466795+11.20048
  • 10+80.3034010+10.40210
  • 25+72.8588825+9.43778
  • 50+67.7271650+8.77304
  • 100+62.97760100+8.15781
  • 250+57.23908250+7.41447
  • 500+55.08899500+7.13595
库存:1
