1555
Watertight Plastic - Styled Lid
Key Features
• Ideally suited for mounting printed circuit boards or DIN rail mounted
components (see photo features below for details).
• “Styled” lid version has three main advantages over our flat lid (1554
series) - also see photo features below:
»» Smooth recessed surface on lid for a membrane keypad or label
»» Standoffs molded in the interior of the lid (except for size “B”). Designed for #6 self tapping screws
»» More modern “styled” look vs. our traditonal flat lid (1554 series)
• ABS Versions are molded from general purpose material which carries
a flammability rating of UL94-HB. For indoor use.
• Polycarbonate versions are UV stabilized for outdoor use. Gray polycarb carries a UL94-5VA rating.
• Polycarbonate versions are UL 508 listed (File # E65324).
• Enclosure color is a light gray (RAL 7035).
• Gasketed lid with two piece “tongue & groove” construction provides
protection against access of oil, dust and water.
• Gasket is one piece made from high temperature, U.L. listed silicone.
• Designed to meet IP 66 & NEMA 4, 4X, 12 & 13 ratings.
• Lid is secured with included M4 stainless steel machine screws which
are threaded into integral stainless steel bushings for repetitive assembly & disassembly. All hardware is stainless steel to avoid corrosion
caused by dissimilar metals.
• Lid screws are self captivating (lid holes are threaded with the first installation of lid screws).
• Internal features are maximized for mounting options and vary with size:
»» Internal DIN rail mounting tabs molded into most models, except
sizes “C” and “D”.
»» Threaded (M3) integral brass inserts and/or standoffs (for #6 self
tapping screws) for P.C. board or inner panel mounting in all but
the smallest size (“B”).
»» Vertical P.C. card guides (for 1.5 mm thick P.C. boards) are molded
in all but the smallest size (“B”).
www.hammondmfg.com
Accessories
Inner Panels
Foot Kit
USA
Canada
Quebec
Europe (UK)
Australia
(716) 630-7030
(519) 822-2960
(450) 975-1884
01256 812812
+61-8-8240-2244
36
1555
PC board mounting bosses molded
into the lid as well
as the box.
Shown here with
galvanized steel inner
panel installed
Feet kit can be
installed and
locked in place
either vertically or
horizontally
Wall or shelf-mount
through holes in the
back og the enclosure (outside the
gasket perimeter).
L
D
www.hammondmfg.com
D
W
USA
Canada
Quebec
Europe (UK)
Australia
(716) 630-7030
(519) 822-2960
(450) 975-1884
01256 812812
+61-8-8240-2244
37
1555
Lid
Screws
Units
Length
(L)
Width
(W)
Total
Height
(D+D)
Inner
Panel
Foot Kit
Replacement
Gasket
1555B2GY
4
in
mm
2.6
65
2.6
65
1.6
40
1554BPL
1554FT
1554BGASKET
1555EGY
1555E2GY
4
in
mm
3.5
90
3.5
90
2.4
60
1554EPL
1554FT
1554EGASKET
1555EEGY
1555EE2GY
4
in
mm
3.5
90
3.5
90
90.5
3.56
1554EPL
1554FT
1554EGASKET
1555CGY
1555C2GY
4
in
mm
4.7
120
2.6
65
1.6
40
1554CPL
1554FT
1554CGASKET
1555DGY
1555D2GY
4
in
mm
4.7
120
2.6
65
2.4
60
1554CPL
1554FT
1554CGASKET
1555FGY
1555F2GY
4
in
mm
4.7
120
3.5
90
2.4
60
1554FPL
1554FT
1554FGASKET
1555GGY
1555G2GY
4
in
mm
4.7
120
3.5
90
3.15
80
1554FPL
1554FT
1554FGASKET
1555NGY
1555N2GY
4
in
mm
4.7
120
4.7
120
2.4
60
1554NPL
1554FT
1554NGASKET
1555PGY
1555P2GY
4
in
mm
4.7
120
4.7
120
3.15
80
1554NPL
1554FT
1554NGASKET
1555JGY
1555J2GY
4
in
mm
6.3
160
3.5
90
2.4
60
1554JPL
1554FT
1554JGASKET
1554KGY
1555K2GY
4
in
mm
6.3
160
3.5
90
3.5
90
1554JPL
1554FT
1554JGASKET
1555RGY
1555R2GY
4
in
mm
6.3
160
6.3
160
2.4
60
1554RPL
1554FT
1554RGASKET
1555SGY
1555S2GY
4
in
mm
6.3
160
6.3
160
3.5
90
1554RPL
1554FT
1554RGASKET
1555HGY
1555H2GY
4
in
mm
7.1
180
4.7
120
2.4
60
1554HPL
1554FT
1554HGASKET
1555TGY
1555T2GY
4
in
mm
7.1
180
4.7
120
3.5
90
1554HPL
1554FT
1554HGASKET
1555UGY
1555U2GY
4
in
mm
7.9
200
4.7
120
3.5
90
1554UPL
1554FT
1554UGASKET
1555VGY
1555V2GY
4
in
mm
9.4
240
6.3
160
3.5
90
1554VPL
1554FT
1554VGASKET
1555VAGY
1555VA2GY
6
in
mm
9.4
240
6.3
160
3.5
90
1554VAPL
1554FT
1554VAGASKET
1555VBGY
1555VB2GY
6
in
mm
9.4
240
6.3
160
4.7
120
1554VAPL
1554FT
1554VAGASKET
1555XGY
1555X2GY
6
in
mm
11.81
300
7.87
200
3.54
90
1554XPL
1554FT
1554XGASKET
1555XAGY
1555XA2GY
6
in
mm
11.81
300
7.87
200
4.72
120
1554XPL
1554FT
1554XGASKET
1555YGY
1555Y2GY
6
in
mm
11.81
300
9.45
240
3.74
95
1554YPL
1554FT
1554YGASKET
1555YAGY
1555YA2GY
6
in
mm
11.81
300
9.45
240
4.72
120
1554YPL
1554FT
1554YGASKET
ABS Plastic With Gray Lid
Polycarbonate With
Gray Lid
1555BGY
www.hammondmfg.com
USA
Canada
Quebec
Europe (UK)
Australia
(716) 630-7030
(519) 822-2960
(450) 975-1884
01256 812812
+61-8-8240-2244
38
很抱歉,暂时无法提供与“1555DGY”相匹配的价格&库存,您可以联系我们找货
