1591XXGFLGY
1591XXGFLGY
    HAMMONDMANUFACTURING
    BOX ABS GRAY 4.82"L X 3.78"W
1591XXGFLGY 数据手册
122.46 [4.82] 146.17 [5.75] B 85.45 [3.36] 34.00 [1.34] INSIDE HEIGHT 108.15 [4.26] 2.00 [.08] WALL THICKNESS 95.91 [3.78] A A B TOP VIEW 6.50 [.26] LID HEIGHT 6.10 [.24] 4.34 [.17] 81.60 [3.21] 38.00 [1.50] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 115.98 [4.57] 99.98 [3.94] 35.25 [1.39] BOX HEIGHT 89.26 [3.51] 4.50 [.18] 89.75 [3.53] INSIDE WIDTH 73.26 [2.88] 116.30 [4.58] INSIDE LENGTH MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE SECTION A-A SIDE VIEW 68.61 [2.70] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. R3.51 [.14] 85.50 [3.37] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE 3.51 Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m [.14] 119.99 [4.72] 4X 3.50 THRU  6.00 X 82° 4X 5.00 THRU  9.00 X 82° PART NUMBERS 5.00 [.20] 93.44 [3.68] INSIDE BOX 68.60 [2.70] 11.50 [.45] 85.50 [3.37] BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW 85.50 [3.37] 89.03 [3.51] 68.60 [2.70] M3-0.5 BRASS INSERTS INSTALLED 5.00 69.80 [2.75] 3.00 [.12] [.20] 115.58 [4.55] 1591XXGFL Enclosure 1591XXGFLBK Black Textured Enclosure Gray Textured Enclosure 1591XXGFLGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] 134.20 [5.28] INSIDE LID Dimensions: mm [inches] 1591XXGFL www.hammondmfg.com ®
1591XXGFLGY 价格&库存
很抱歉,暂时无法提供与“1591XXGFLGY”相匹配的价格&库存,您可以联系我们找货
1591XXGFLGY
  • 1+67.582701+8.47500
  • 10+56.2288110+7.05120
  • 50+52.5342950+6.58790
库存:3
