1591XXGTBU
1591XXGTBU
    HAMMONDMANUFACTURING
    BOX ABS TRN BLUE 4.82"L X 3.78"W
1591XXGTBU 数据手册
122.46 [4.82] B 34.00 [1.34] INSIDE HEIGHT 108.15 [4.26] 2.00 [.08] WALL THICKNESS 95.91 [3.78] A A B TOP VIEW 6.50 [.26] LID HEIGHT 4.34 [.17] 6.10 [.24] 81.60 [3.21] 38.00 [1.50] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 115.98 [4.57] 35.25 [1.39] BOX HEIGHT 73.26 [2.88] 4.50 [.18] 116.30 [4.58] INSIDE LENGTH 89.75 [3.53] INSIDE WIDTH 99.98 [3.94] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. SECTION A-A SIDE VIEW R3.51 [.14] 85.50 [3.37] 3.51 [.14] 119.99 [4.72] 115.58 [4.55] 5.00 89.03 [3.51] [.20] 68.60 [2.70] 93.44 [3.68] 85.50 [3.37] INSIDE BOX 68.61 [2.70] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE 89.26 [3.51] BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW NOTE Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m PART NUMBERS 5.00 1591XXG Enclosure 1591XXGBK 1591XXGGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] 68.60 [2.70] [.20] Black Textured Enclosure Gray Textured Enclosure 85.50 [3.37] M3-0.5 BRASS INSERTS INSTALLED (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 4X 3.50 THRU  6.00 X 82° INSIDE LID Dimensions: mm [inches] 1591XXG www.hammondmfg.com ®
1591XXGTBU
物料型号:HAMMOND 1591XXG®
器件简介:1591XXG® 是 Hammond Manufacturing 公司生产的一款塑料外壳,用于容纳和保护电路板和其他电子组件。
引脚分配:外壳和盖子上安装有 M3-0.5 黄铜嵌件,用于固定电路板。
外壳和盖子的 PCB 柱接受 #4 x 1/4" 自攻螺丝。
参数特性: - 内部尺寸:长 89.26mm x 宽 68.60mm x 高 34.00mm - 外壳高度:115.98mm - 盖子高度:6.50mm - 壁厚:2.00mm - 材料:FRABS UL 94-V0 塑料,其他材料/颜色可咨询工厂
功能详解:外壳设计用于容纳电路板,盖子通过 M3-0.5 x 10mm 机器螺丝固定。
外壳和盖子可以进行工厂修改(如铣削、钻孔、打印等),以适应特定需求。
应用信息:适用于需要保护电路板免受物理损害或环境因素影响的应用场合。
封装信息:外壳采用黑色纹理,盖子螺丝为黑色 M3-0.5 x 10mm。
其他颜色和材料可根据需要提供。
购买时包括盒子、盖子、4个盖子螺丝和已安装的黄铜嵌件。
推荐扭矩为 (43-50) Ozf.in / (30-35) cN.m。
产品可以通过电子邮件 mjm@hammondmfg.com 联系工厂进行定制。
STEP 或 IGES 格式的实体模型也可提供。
1591XXGTBU 价格&库存
很抱歉,暂时无法提供与“1591XXGTBU”相匹配的价格&库存,您可以联系我们找货
