1591XXSFLBK
1591XXSFLBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 4.43"L X 3.33"W
1591XXSFLBK 数据手册
136.24 [5.36] 40.00 [1.57] INSIDE HEIGHT 112.52 [4.43] 97.80 B [3.85] 69.90 [2.75] 74.17 [2.92] A A B TOP VIEW 6.50 [.26] LID HEIGHT 4.50 [.18] 49.99 [1.97] 6.11 [.24] 84.62 [3.33] 44.00 [1.73] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 41.25 [1.62] BOX HEIGHT 105.79 [4.17] 77.90 [3.07] 61.90 [2.44] 105.95 [4.17] INSIDE LENGTH SECTION A-A SIDE VIEW 73.30 [2.89] 78.05 [3.07] INSIDE WIDTH 2.00 [.08] WALL THICKNESS 89.79 [3.54] 56.90 [2.24] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. R3.51 [.14] 73.30 [2.89] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE 3.51 Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m [.14] 110.06 [4.33] 4X 3.50 THRU  6.00 X 82° 4X 5.00 THRU  9.00 X 82° PART NUMBERS 82.16 [3.23] 5.00 [.20] 56.90 [2.24] 73.30 [2.89] 77.75 [3.06] 11.50 [.45] BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW INSIDE BOX M3-0.5 BRASS INSERTS INSTALLED 5.00 63.00 [2.48] 56.90 [2.24] [.20] 3.00 [.12] 1591XXSFL Enclosure 1591XXSFLBK Black Textured Enclosure Gray Textured Enclosure 1591XXSFLGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] 105.65 [4.16] 123.30 [4.85] INSIDE LID Dimensions: mm [inches] 1591XXSFL www.hammondmfg.com ®
1591XXSFLBK 价格&库存
很抱歉,暂时无法提供与“1591XXSFLBK”相匹配的价格&库存,您可以联系我们找货
