1591XXDFLGY
1591XXDFLGY
    HAMMONDMANUFACTURING
    BOX ABS GRAY 6"L X 3.25"W
1591XXDFLGY 数据手册
176.15 152.43 [6.93] [6.00] B 46.50 [1.83] INSIDE HEIGHT 137.25 [5.40] 71.97 [2.83] A A B TOP VIEW 6.50 [.26] LID HEIGHT 6.10 [.24] 4.34 [.17] 82.43 [3.25] 67.25 [2.65] 2.00 [.08] WALL THICKNESS 75.40 [2.97] INSIDE WIDTH 50.50 [1.99] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 47.75 [1.88] BOX HEIGHT 145.00 [5.71] 129.00 [5.08] 75.00 [2.95] 59.00 [2.32] 145.40 [5.72] INSIDE LENGTH 4.50 [.18] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE SECTION A-A SIDE VIEW 54.25 [2.14] R4.50 [.18] 114.75 [4.52] 3.50 [.14] 149.96 [5.90] 4X 5.00 THRU  9.00 X 82° 4X 3.50 THRU  6.00 X 82° Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m PART NUMBERS 5.00 [.20] 54.25 [2.14] 79.96 [3.15] 114.75 [4.52] INSIDE BOX 114.75 [4.52] 75.55 [2.97] 11.50 [.45] M3-0.5 BRASS INSERTS INSTALLED BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW 54.25 [2.14] 5.00 [.20] 145.55 [5.73] 1591XXDFL Enclosure Black Textured Enclosure 1591XXDFLBK 57.00 1591XXDFLGY [2.24] Gray Textured Enclosure ACCESSORIES 3.00 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] [.12] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] 165.00 [6.50] INSIDE LID Dimensions: mm [inches] 1591XXDFL www.hammondmfg.com ®
1591XXDFLGY
物料型号:HAMMOND 1591XXDFL®
器件简介:这是一个由HAMMOND制造的塑料外壳,用于容纳和保护电路板。
引脚分配:外壳和盖子的PCB柱接受#4 x 1/4"自攻螺丝。
参数特性: - 内部尺寸:长度114.75mm(4.52英寸),宽度54.25mm(2.14英寸),高度47.75mm(1.88英寸)。
- 外壳高度:145.00mm(5.71英寸)。
- 盖子高度:6.50mm(.26英寸)。
- 壁厚:2.00mm(.08英寸)。
- 最大PCB尺寸:长度114.75mm(4.52英寸),宽度54.25mm(2.14英寸)。
功能详解:外壳由FRABS UL 94-V0塑料制成,可提供工厂修改(如铣削、钻孔、打印等),并可提供其他材料或颜色。
外壳和盖子的PCB柱接受自攻螺丝,用于固定电路板。
外壳配有4个盖子螺丝和安装的铜螺母。
应用信息:适用于需要保护电路板免受物理损害的应用,如工业控制、医疗设备、测试和测量设备等。
封装信息:外壳为黑色或灰色纹理,盖子螺丝为黑色,型号为1591XXDFLBK和1591XXDFLGY。
配件包括1591MS100(100个装的PCB螺丝)和1593ATS50(50个装的自攻螺丝)。
1591XXDFLGY 价格&库存
很抱歉,暂时无法提供与“1591XXDFLGY”相匹配的价格&库存,您可以联系我们找货
