1591XXTFLBK
1591XXTFLBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 4.85"L X 3.28"W
1591XXTFLBK 数据手册
146.99 [5.79] 123.27 [4.85] 107.50 [4.23] 55.00 [2.17] INSIDE HEIGHT B 72.81 [2.87] 2.00 [.08] WALL THICKNESS 67.50 [2.66] A A B TOP VIEW 6.50 [.26] LID HEIGHT 4.34 [.17] 6.11 [.24] 83.27 [3.28] 59.00 [2.32] M3-0.5 X10mm MACHINE SCREW SECTION B-B END VIEW 56.25 [2.21] BOX HEIGHT 115.00 [4.53] 75.00 [2.95] 4.50 [.18] 59.00 [2.32] 115.65 [4.55] INSIDE LENGTH 99.00 [3.90] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE 54.50 [2.15] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. R4.00 [.16] SECTION A-A SIDE VIEW 85.00 [3.35] 75.65 [2.98] INSIDE WIDTH 85.00 [3.35] 120.80 [4.76] 4X 3.50 THRU  6.00 X 82° (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 3.50 NOTE [.14] Purchased assembly includes box, lid, 4 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m 4X 5.00 THRU  9.00 X 82° PART NUMBERS 80.80 [3.18] 5.00 [.20] 54.50 [2.15] 85.00 [3.35] 76.39 [3.01] 11.50 [.45] BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW INSIDE BOX M3-0.5 BRASS INSERTS INSTALLED 5.00 58.40 [2.30] 54.50 [2.15] 3.00 [.12] [.20] 1591XXTFL Enclosure Black Textured Enclosure 1591XXTFLBK Gray Textured Enclosure 1591XXTFLGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] 116.39 [4.58] 135.00 [5.31] INSIDE LID Dimensions: mm [inches] 1591XXTFL www.hammondmfg.com ®
1591XXTFLBK 价格&库存
很抱歉,暂时无法提供与“1591XXTFLBK”相匹配的价格&库存,您可以联系我们找货
1591XXTFLBK
  • 1+141.309531+18.25582
  • 5+118.839325+15.35289
  • 10+110.3722510+14.25903
  • 25+100.1815225+12.94248
  • 50+93.1437350+12.03327
  • 100+86.63218100+11.19204
  • 250+79.07800250+10.21611
库存:36
1591XXTFLBK
  • 1+103.33651
  • 10+100.24360
  • 50+97.23400
库存:11
