1591XXEFLBK
1591XXEFLBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 7.62"L X 4.47"W
1591XXEFLBK 数据手册
217.13 193.41 [8.55] [7.61] 177.50 [6.99] 57.00 [2.24] INSIDE HEIGHT B 102.95 [4.05] 113.41 [4.47] A A B 2.00 [.08] WALL THICKNESS 97.50 [3.84] 109.16 [4.30] INSIDE WIDTH 61.00 [2.40] M3-0.5 X10mm MACHINE SCREW TOP VIEW SECTION B-B END VIEW 58.25 [2.29] BOX HEIGHT 6.50 [.26] LID HEIGHT 185.00 [7.28] 168.50 [6.63] 8.00 [.31] 105.00 [4.13] 89.00 [3.50] 185.65 [7.31] INSIDE LENGTH 4.50 [.18] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. SECTION A-A SIDE VIEW 22.50 [.89] 6X 3.50 THRU  6.00 X 82° 190.94 [7.52] 5.00 [.20] 22.50 [.89] 66.25 [2.61] BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW INSIDE BOX 66.25 [2.61] 4X 5.00 THRU  9.00 X 82° R4.25 [.17] 3.50 [.14] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Purchased assembly includes box, lid, 6 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m PART NUMBERS 84.50 [3.33] 110.94 [4.37] 86.75 [3.42] 106.53 [4.19] 11.50 [.45] M3-0.5 BRASS INSERTS INSTALLED 66.25 [2.61] 22.50 [.89] 90.00 [3.54] 84.50 [3.33] 5.00 3.00 [.12] [.20] 186.53 [7.34] 206.00 [8.11] INSIDE LID Dimensions: mm [inches] 1591XXEFL Enclosure Black Textured Enclosure 1591XXEFLBK Gray Textured Enclosure 1591XXEFLGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] 1591XXEFL www.hammondmfg.com ®
1591XXEFLBK 价格&库存
很抱歉,暂时无法提供与“1591XXEFLBK”相匹配的价格&库存,您可以联系我们找货
