1590BS
1590BS
    HAMMONDMANUFACTURING
    BOX ALUM UNPAINTED 4.41"LX2.38"W
1590BS 数据手册
112.00 [4.409] A 38.00 [1.496] INSIDE HEIGHT 102.10 [4.020] 50.50 [1.988] B B 54.97 [2.164] INSIDE WIDTH 60.50 [2.382] A 42.00 [1.654] TOP VIEW SECTION A-A END VIEW 6.00 [.236] 4X 6-32 UNC  11.00  3.90  3.00 2.00 [.079] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 107.24 [4.222] 38.00 [1.496] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 56.50 [2.224] 2.00 [.079] PART NUMBERS 96.00 [3.780] SECTION B-B SIDE VIEW 1590BS Enclosure 1590BS Natural Finish Enclosure 1590BSBK Black Textured Enclosure 1590BS Liquid Resistant Enclosure (Silicone Gasket) 1590W BS Natural Finish Enclosure 1590W BSBK Black Textured Enclosure ACCESSORIES INSIDE BOX 4X 4.00 [.157] 102.10 [4.020] 103.46 [4.073] 52.06 [2.050] Liquid Resistant Cover Screws 2.00 [.079] Stainless Steel Cover Screw s (Pkg 100) [6-32 x 1/2" With O-Ring] Black Stainless Steel Cover Screw s (Pkg 100) [6-32 x 1/2" W ith O-Ring] 1590WMS100 1590WMS100BK Standard Cover Screws Plated Cover Screw s (Pkg 100) [6-32 x 1/2"] Black Cover Screw s (Pkg 100) [6-32 x 1/2"] 50.50 [1.988] 4.00 [.157] INSIDE LID NOTE Purchased assembly includes box, lid and 4 cover screws. Box and lid are made from Diecast Aluminum Alloy. Silicone Gasket supplied with liquid resistant enclosure. Recommended Torque: 50-55 cN.m [71-78 ozf.in] Recommended Torque with Gasket : 25-30 cN.m [36-43 ozf.in] 106.47 [4.192] INSIDE LENGTH 4.19 [.165] 44.50 [1.752] Dimensions: mm [inches] 1590MS100 1590MS100BK 1590BS www.hammondmfg.com ®
1590BS
物料型号:1590BS
器件简介:这是一个由Hammond Manufacturing生产的铝制外壳,具有多种表面处理和密封选项。
引脚分配:文档中没有提供关于引脚分配的信息。
参数特性:外壳尺寸为长112.00mm x 宽102.10mm x 高38.00mm,内部尺寸为长106.47mm x 宽50.50mm x 高2.00mm。外壳和盖子由压铸铝合金制成,配有硅胶垫圈以提供液体防护。
功能详解:外壳可以进行工厂修改,如铣削、钻孔、打印等。可以联系工厂获取报价。提供STEP或IGES格式的实体模型。
应用信息:适用于需要液体防护的电子设备。
封装信息:外壳和盖子由压铸铝合金制成,配有硅胶垫圈。推荐扭矩为50-55 cN.m(71-78 ozf.in),使用垫圈时推荐扭矩为25-30 cN.m(36-43 ozf.in)。
配件信息:包括自然色和黑色纹理的外壳,以及液体防护型外壳。还提供不锈钢盖螺丝和标准盖螺丝等配件。
1590BS 价格&库存
很抱歉,暂时无法提供与“1590BS”相匹配的价格&库存,您可以联系我们找货
1590BS
    • 1+93.19343
    • 10+89.46528
    • 50+85.71630
    库存:18
