RP1080
RP1080
    HAMMONDMANUFACTURING
    BOX PLSTC OFF WHT 4.13"LX2.95"W
RP1080 数据手册
RITEC - Watertight Polycarbonate (RP Series) Path: Home > Enclosure Index >MOREnclosures > RITEC - Watertight Polycarbonate click to enlarge (Assembled View) click to enlarge (Open View) Key Features: z z z z z z z z z z z Ideally suited for mounting printed circuit boards or DIN rail mounted components. Material - Polycarbonate (material carries a UL flammability rating of UL94 HB). Color is an off white with a light texture. Gasketed lid with two piece "tongue & groove" construction provides protection against access of oil, dust and water. Rubber gasket is included and must be field installed. Lid includes smooth recessed area for membrane, label or silkscreen (see chart below for recess size). Designed to meet IP 65. Lid is secured with self captivating - M3.5 stainless steel machine screws (included), threaded into integral stainless steel bushings (for repetitive assembly & disassembly). All stainless steel hardware to avoid corrosion caused by dissimilar metals. Lid screws are self captivating (lid holes are threaded with the first installation of lid screws). Internal features are maximized for mounting options: { Internal DIN rail mounting tabs - molded in. { Options vary with size. See photo tables for internal views of each size. Link here to photo tables of each part number. 3D AutoCAD Height Solid Model Lid Part No. Reader .dwg File Units Length Width (Includes .igs & .stp Recess Size Lid) File (zipped) files (zipped) inches 2.56 RP1020 565K 265K 335K mm 65 inches 3.35 RP1060 326K 228K 307K mm 85 2.36 1.57 1.54 x 2.05 60 40 39 x 52 3.15 2.17 2.32 x 2.83 80 55 59 x 72 inches 4.13 RP1080 324K 253K 2.95 1.57 2.56 x 3.07 75 40 65 x 78 2.95 2.17 2.56 x 3.07 75 55 65 x 78 3.35 2.17 3.03 x 3.90 85 55 77 x 99 inches 5.71 4.13 1.57 4.57 x 3.78 mm 145 105 40 116 x 96 inches 5.71 4.13 2.36 4.57 x 3.78 mm 145 105 60 116 x 96 inches 6.50 3.35 2.17 2.76 x 5.47 85 55 70 x 139 inches 6.50 4.92 2.95 5.43 x 4.57 mm 165 125 75 138 x 116 inches 7.32 5.75 2.95 5.08 x 5.91 mm 186 146 75 129 x 150 inches 8.66 6.50 2.36 7.28 x 5.91 mm 220 165 60 185 x 150 inches 8.66 6.50 3.35 7.28 x 5.91 mm 165 85 185 x 150 mm 425K 105 inches 4.13 RP1090 324K 251K mm 424K 105 inches 4.92 RP1130 325K 268K mm 391K RP1200 319K 233K 393K RP1210 308K 220K 346K RP1170 331K 243K mm 434K RP1240 326K 249K 298K RP1280 284K 213K 293K RP1450 333K 259K 361K RP1460 385K 426K 125 1,513K 165 220 Link here to photo tables of each part number Accessories Wall Mounting Feet (Polycarbonate): MF0040 click to enlarge click to enlarge Includes mounting hardware Attached to a polycarbonate RP series and wall anchors enclosure Part No. Use With Enclosure Part Numbers MF0040 Smaller Enclosures - RP1020-RP1280 Exactly what you are looking for??? Link to our stocking distributors - most have "on-line" pricing, stock check and ordering!!! Order from your favorite distributor HOME PAGE Copyright; © 2007-2009 Hammond Mfg Co Inc URL: http://www.hammondmfg.com
RP1080 价格&库存
很抱歉,暂时无法提供与“RP1080”相匹配的价格&库存,您可以联系我们找货
