1590HBK
1590HBK
    HAMMONDMANUFACTURING
    BOX ALUM BLACK 2.07"L X 1.5"W
1590HBK 数据手册
52.50 [2.067] 27.30 [1.075] INSIDE HEIGHT 43.00 [1.693] A 34.13 [1.344] INSIDE WIDTH 38.00 [1.496] B B 28.50 [1.122] A 6.00 [.236] TOP VIEW 2.20 [.087] 31.00 [1.220] SECTION A-A END VIEW 49.50 [1.949] 2.00 [.079] 27.00 [1.063] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 4X 6-32 UNC 0.41 NOTE 21.50 [.846] 1.50 [.059] 35.00 [1.378] 48.63 [1.914] INSIDE LENGTH Recommended Torque: 50-55 cN.m [71-78 ozf.in] Recommended Torque with Gasket : 25-30 cN.m [36-43 ozf.in] PART NUMBERS SECTION B-B SIDE VIEW 43.98 [1.732] Purchased assembly includes box, lid and 4 cover screws. Box and lid are made from Diecast Aluminum Alloy. Silicone Gasket supplied with liquid resistant enclosure. 1590H Enclosure 1590H Natural Finish Enclosure 1590HBK Black Textured Enclosure 1590H Liquid Resistant Enclosure (Silicone Gasket) 1590W H Natural Finish Enclosure 1590W HBK Black Textured Enclosure ACCESSORIES 36.00 [1.417] 4X 4.00 [.157] INSIDE BOX 2.00 [.079] Liquid Resistant Cover Screws Stainless Steel Cover Screw s (Pkg 100) [6-32 x 1/2" W ith O-Ring] Black Stainless Steel Cover Screw s (Pkg 100) [6-32 x 1/2" W ith O-Ring] 2.46 [.097] INSIDE LID 1590W MS100BK Standard Cover Screws 29.68 19.74 [1.169] [.777] 43.98 [1.732] 1590W MS100 Plated Cover Screw s (Pkg 100) [6-32 x 1/2"] Black Cover Screw s (Pkg 100) [6-32 x 1/2"] 4.00 [.157] Dimensions: mm [inches] 1590MS100 1590MS100BK 1590H www.hammondmfg.com ®
1590HBK
物料型号:1590H系列外壳。
器件简介:Hammond的1590H系列外壳是用于电子设备的保护性外壳,可定制修改(如铣削、钻孔、打印等),并提供固体模型文件。
引脚分配:文档中未提供具体的引脚分配信息。
参数特性:外壳内部尺寸为27.30mm(高度)、52.50mm(宽度)、43.00mm(长度),以及36.00mm(内部盒子深度)和43.98mm(内部盖子深度)。外壳和盖子由压铸铝合金制成,配有硅胶垫圈。
功能详解:外壳可提供自然色或黑色纹理表面处理,并且有适用于液体抵抗的版本(1590WH和1590WHBK)。推荐使用25-30 cN.m [36-43 ozf.in] 的扭矩安装垫圈。
应用信息:适用于需要保护电子设备的场合,如工业环境。
封装信息:包括盒子、盖子和4个盖子螺丝。附件包括不锈钢盖螺丝和标准盖螺丝。
1590HBK 价格&库存
很抱歉,暂时无法提供与“1590HBK”相匹配的价格&库存,您可以联系我们找货
1590HBK
  • 1+118.151171+14.77801
  • 5+101.037795+12.63752
  • 10+94.4380710+11.81204
  • 25+86.3734925+10.80335
  • 50+80.7329250+10.09784
  • 100+75.45760100+9.43802
  • 250+72.07092250+9.01442
库存:13
1590HBK
  • 1+94.48475
库存:1
