1598DSGYPBK
1598DSGYPBK
    HAMMONDMANUFACTURING
    BOX ABS BLK/GRAY 7.08"L X 8.08"W
1598DSGYPBK 数据手册
2 Bottom View of Assembly 1 Front Face A SECTION A-A (Side View Inside Assembly) n11.00 n 8.37 [.433] (Bottom Boss n) [.330] (Top Boss n) Detail View of Boss (Located on Top and Bottom Cover) 3.85 [.152] 179.75 [7.077] P.C. Board n 8.00 B A Bottom Cover 59.00 [2.323] (Inner Box Height) 184.06 [7.246] SECTION B-B (Inside of Bottom Cover) End View of Assembly B B [.315] Top Cover 1.92 [.075] (PCB dist from inner wall) End Panel 205.10 [8.075] 195.31 [7.689] (Inner Box Width) .50 [.020] (PCB dist from end panel) Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Solid models of this enclosure available in STEP or IGES. Contact Factory mjm@hammondmfg.com NOTE Purchased Assembly includes top and bottom cover, front and end aluminum panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4 rubber feet. B 167.30 [6.587] (Inner Box Length) P.C. Board Aligned on Bosses 63.20 [2.488] 1598D Instrument Case Maximum P.C. Board Size 77.15 [3.037] Front/Rear Panel (Dashed Line Indicates Viewing Area) A 50.00 [1.969] 193.60 [7.622] (Viewing Area) 55.15 [2.171] (Viewing Area) 58.00 [2.283] 191.48 [7.539] 12.00 [.472] 9.71 [.382] P.C. Board (Not Supplied) n3.51 (8X) 50.00 [1.969] [.138] FLAME RETARDANT ABS (UL94-VO) Bla ck Enclosure w ith Alum inum Pa ne ls 1598DBK Gre y Enclosure w ith Alum inum Pa ne ls 1598DGY Bla ck EMI/RFI Shie lde d 1598RDBK NON-FLAME RETARDANT GPABS (UL94-HB) Gre y Enclosure w ith Alum inum Pa ne ls 1598DSGY Gre y Enclosure w ith Bla ck Pla stic Pa ne ls 1598DSGYPBK ACCESSORIES Bla ck Pla stic Pa ne ls 1598PLDBK Rubbe r Fe e t (Pkg 24) 1421T2 For 1598 FR-ABS 1591MS100 Cover Screws (Pk g 100) [M3 - 0.5 x 10mm] For 1598 GPABS 1591TS100 Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)] For Both Mode ls 1598ATS100 PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)] 50.00 [1.969] 198.00 [7.795] 1.65 [.065] 23.08 [.908] 120.15 [4.730] 166.30 [6.547] 2 1598D 20.74 [.817] 1 A
1598DSGYPBK 价格&库存
很抱歉,暂时无法提供与“1598DSGYPBK”相匹配的价格&库存,您可以联系我们找货
