1455D601BU
1455D601BU
    HAMMONDMANUFACTURING
    BOXALUMBLUE2.36"LX1.67"W
1455D601BU 数据手册
8 7 6 5 4 D 1 D 2 X n0.165 in THRU w n0.230 in X 82.0° 35.60 mm [1.402 in] 20.00 `0.42 mm [0.787 `0.017 in] 2 42.43 mm [1.670 in] 39.50 `0.37 mm [1.555 `0.015 in] 1.20 mm [0.047 in] 3 0.30 mm [0.012 in] 23.00 mm [0.906 in] 22.93 mm [0.903 in] 2.05 mm [0.081 in] C 2.00 mm [0.079 in] 1.46 mm TYP 1.80 mm TYP [0.057 in] [0.071 in] 1.63 mm [0.064 in] 35.60 mm [1.402 in] EXTRUSION PROFILE C ENDPLATE 33.10 mm [1.303 in] EXPLODED ASSEMBLY VIEW **DESIGNED FOR 39MM WIDE PC BOARD** Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 44.62 mm [1.757 in] 3.00 mm [0.118 in] A B 36.68 mm [1.444 in] 60.00 `0.50 mm [2.362 `0.020 in] PART NUMBERS Clear Anodized Black Anodized Blue Anodized Red Anodized 20.18 mm [0.794 in] A 6.00 mm [0.236 in] 35.60 mm [1.402 in] OPEN BEZEL 7 1455D601 1455D601BK 1455D601BU 1455D601RD ACCESSORIES See website for accessories. SECTION A-A A 1455D601 42.50 mm [1.673 in] 8 6 B 1455D601 25.12 mm [0.989 in] A NOTE Purchased assembly includes box, plastic bezels, End Panels, Custom #6 Taptight screws and self adhesive rubber feet Box made from Extruded Aluminum 6063-T5 Bezels made with polycarbonate. End Plates made from 5052-H32 Aluminum 5 4 3 2 1
1455D601BU
物料型号为1455D601,该产品为Hammond Manufacturing生产的铝挤压成型外壳,适用于39mm宽的PCB板。
器件简介包括聚碳酸酯制成的前盖和由5052-H32铝制成的端板。
引脚分配未在文档中明确说明。
参数特性包括外壳尺寸、材料和颜色选项。
功能详解涉及外壳的组装视图和材料信息。
应用信息指出该外壳设计用于容纳PCB板,并且可以进行工厂修改,如铣削、钻孔、打印等。
封装信息包括外壳的尺寸和材料,以及可选的配件和颜色。
更多详细信息和配件,建议访问Hammond Manufacturing的官方网站。
1455D601BU 价格&库存
很抱歉,暂时无法提供与“1455D601BU”相匹配的价格&库存,您可以联系我们找货
1455D601BU
  • 1+157.545271+20.36260
  • 10+118.1152410+15.26630
  • 50+110.2467250+14.24930
库存:5
1455D601BU
  • 1+191.597641+24.76385
1455D601BU
  • 1+140.86798
  • 10+135.24451
  • 20+129.60021
库存:2
