1591XXFFLBK
1591XXFFLBK
    HAMMONDMANUFACTURING
    BOX ABS BLACK 8.7"L X 5.91"W
1591XXFFLBK 数据手册
232.00 [9.13] 244.00 [9.61] B 57.34 [2.26] INSIDE HEIGHT 205.00 [8.07] 133.50 [5.26] A A B TOP VIEW 7.00 [.28] LID HEIGHT 11.74 [.46] 5.10 [.20] M3-0.5 X10mm" MACHINE SCREW 6.50 [.26] 8.25 [.32] 60.50 [2.38] BOX HEIGHT 204.47 [8.05] INSIDE LENGTH 5.00 [.20] 1.50 [.06] 63.50 [2.50] SECTION B-B END VIEW 5.00 [.20] MAX SIZE PCB. FITS IN BOX OR IN LID NOT SUPPLIED WITH ENCLOSURE 6X Ø3.50 THRU 50.00 [1.97] 60.00 [2.36]  Ø6.00 X 82° 50.00 [1.97] 4X Ø5.00 THRU C  Ø 9.00 X 82° 60.00 [2.36] 138.42 [5.45] [.20] 100.00 [3.94] 50.00 [1.97] 60.00 [2.36] BOX AND LID PCB POSTS ACCEPT #4 X1/4" SELF-TAPPING SCREW INSIDE BOX Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 3.50 R5.00 [.20] [.14] NOTE Purchased assembly includes box, lid, 6 cover screws and installed brass inserts. Enclosure molded from FRABS UL 94-V0 Plastic. Other materials / colours available consult factory. Recommended Torque : (43-50) Ozf.in / (30-35) cN.m PART NUMBERS 5.00 143.68 [5.66] 133.00 [5.24] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) DETAIL C SCALE 1 : 1 214.68 [8.45] 126.00 [4.96] INSIDE WIDTH 204.00 [8.03] 194.00 [7.64] 133.00 [5.24] 123.00 [4.84] SECTION A-A SIDE VIEW 2.50 [.10] 3.00 [.12] WALL THICKNESS 150.00 [5.91] 134.00 [5.28] M3-0.5 BRASS INSERTS INSTALLED 100.00 [3.94] 12.74 [.50] 5.00 [.20] 1591XXFFL Enclosure 133.50 Black Textured Enclosure 1591XXFFLBK [5.26] Gray Textured Enclosure 1591XXFFLGY ACCESSORIES 1591MS100BK (Pkg 100) Black Cover Screws [M3-0.5 X10mm] 3.21 Plated Cover Screws [M3-0.5 X10mm] 1591MS100 (Pkg 100) [.13] P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) [#4 x 1/4" self-tapping (6.4mm)] 209.18 [8.24] 232.00 [9.13] INSIDE LID Dimensions: mm [inches] 1591XXFFL www.hammondmfg.com ®
1591XXFFLBK 价格&库存
很抱歉,暂时无法提供与“1591XXFFLBK”相匹配的价格&库存,您可以联系我们找货
1591XXFFLBK
  • 1+161.21662
库存:2
