1598HSGY
1598HSGY
    HAMMONDMANUFACTURING
    BOX ABS GRAY 11.06"L X 7.87"W
1598HSGY 数据手册
2 Bottom View of Assembly A 1 Front Face SECTION A-A (Side View Inside Assembly) n11.47 [.451] (Bottom Boss n) n 8.47 Detail View of Boss [.333] (Top Boss n) (Located on Top and Bottom Cover) 3.25 [.128] n 8.00 [.315] 280.89 [11.059] B B P.C. Board A 33.50 [1.319] (Inner Box Height) Bottom Cover 179.00 [7.047] SECTION B-B (Inside of Bottom Cover) End View of Assembly B Top Cover 2.93 [.115] (PCB dist from inner wall) End Panel 199.89 [7.870] .50 [.020] (PCB dist from end panel) B Maximum P.C. Board Size 185.89 [7.319] (Viewing Area) 15.15 [.597] 128.16 [5.046] 35.00 [1.378] 12.39 [.488] FLAME RETARDANT ABS (UL94-VO) Bla ck Enclosure w ith Alum inum Pa ne ls 1598HBK Gre y Enclosure w ith Alum inum Pane ls 1598HGY Bla ck EMI/RFI Shie lde d 1598RHBK NON-FLAME RETARDANT GPABS (UL94-HB) Gre y Enclosure w ith Alum inum Pane ls 1598HSGY Gre y Enclosure w ith Bla ck Pla stic Pa ne ls 1598HSGYPBK ACCESSORIES Bla ck Pla stic Pa ne ls 1598PLHBK Rubbe r Fee t (Pkg 24) 1421T2 For 1598 FR-ABS 1591MS100 Cover Screws (Pk g 100) [M3 - 0.5 x 10mm] For 1598 GPABS 1591TS100 Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)] For Both Mode ls 1598ATS100 PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)] 8.85 [.348] P.C. Board (Not Supplied) 184.30 [7.256] 30.50 [1.201] (Viewing Area) NOTE 1598H Instrument Case 269.69 [10.618] (Inner Box Length) P.C. Board Aligned on Bosses Front/Rear Panel (Dashed Line Indicates Viewing Area) Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Solid models of this enclosure available in STEP or IGES. Contact Factory mjm@hammondmfg.com Purchased Assembly includes top and bottom cover, front and end aluminum panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4 rubber feet. 41.00 [1.614] A 190.16 [7.487] (Inner Box Width) 154.00 [6.063] n3.51 (8X) [.138] 190.00 [7.480] 1.65 [.065] 23.10 [.909] 89.00 [3.504] 44.50 [1.752] 1598H 89.00 [3.504] 268.70 [10.579] 2 1 A
1598HSGY 价格&库存
很抱歉,暂时无法提供与“1598HSGY”相匹配的价格&库存,您可以联系我们找货
