RP1285C
RP1285C
    HAMMONDMANUFACTURING
    BOX ABS GRAY/CLR 7.35"L X 5.78"W
RP1285C 数据手册
RITEC - Watertight ABS Plastic (RP Series) Path: Home > Enclosure Index > MOREnclosures > RITEC - Watertight ABS Plastic click to enlarge click to enlarge (Assembled View) (Open View) click to enlarge (Assembled View) Clear Lid Key Features: z z z z z z z z z z z Ideally suited for mounting printed circuit boards or DIN rail mounted components. Material - General purpose ABS plastic (material carries a UL flammability rating of UL94 HB). Color is a light gray with a light texture. Also available with a clear polycarbonate lid (see table below). Gasketed lid with two piece "tongue & groove" construction provides protection against access of oil, dust and water. Rubber gasket is included and must be field installed. Lid includes smooth recessed area for membrane, label or silkscreen (see chart below for recess size). Designed to meet IP 65. Lid is secured with self captivating - M3.5 stainless steel machine screws (included), threaded into integral stainless steel bushings (for repetitive assembly & disassembly). All stainless steel hardware to avoid corrosion caused by dissimilar metals. Lid screws are self captivating (lid holes are threaded with the first installation of lid screws). Internal features are maximized for mounting options: { Internal DIN rail mounting tabs - molded in. { Options vary with size. See photo tables for internal views of each size. Link here to photo tables of each part number. 3D Part No. AutoCAD Height Solid Model Lid Part No. ABS with Reader .dwg File Units Length Width (Includes .igs & .stp Recess Size Clear Lid File (zipped) Lid) files (zipped) inches 2.56 RP1025 RP1025C 566K 263K 669K mm 65 inches 3.35 2.36 1.57 1.54 x 2.05 60 40 39 x 52 3.15 2.17 2.32 x 2.83 RP1065 RP1065C mm 527K 367K 85 80 55 59 x 72 2.95 1.57 2.56 x 3.07 75 40 65 x 78 2.95 2.17 2.56 x 3.07 75 55 65 x 78 3.35 2.17 3.03 x 3.90 85 55 77 x 99 inches 5.71 4.13 1.57 4.57 x 3.78 mm 145 105 40 116 x 96 inches 5.71 4.13 2.36 4.57 x 3.78 mm 145 105 60 116 x 96 inches 6.50 3.35 2.17 2.76 x 5.47 85 55 70 x 139 inches 6.50 4.92 2.95 5.43 x 4.57 mm 165 125 75 138 x 116 inches 7.32 5.75 2.95 5.08 x 5.91 mm 186 146 75 129 x 150 inches 8.66 6.50 2.36 7.28 x 5.91 mm 220 165 60 185 x 150 inches 8.66 6.50 3.35 7.28 x 5.91 mm 165 85 185 x 150 585K inches 4.13 RP1085 RP1085C 324K 256K 849K mm 105 inches 4.13 RP1095 RP1095C 327K 254K 847K mm 105 inches 4.92 RP1135 RP1135C 326K 267K 782K RP1205 RP1205C 318K 233K 785K RP1215 RP1215C 308K 223K 692K RP1175 RP1175C 332K 240K 867K RP1245 RP1245C 325K 248K 595K RP1285 RP1285C 283K 212K 664K RP1455 RP1455C 333K 255K 720K RP1465 RP1465C 384K 384K 1,513K mm mm 125 165 220 Link here to photo tables of each part number Accessories Wall Mounting Feet (ABS Plastic): MF0045 click to enlarge Includes mounting hardware and wall anchors click to enlarge Attached to ABS plastic RP series enclosure MF0055 click to enlarge Includes mounting hardware and wall anchors Part No. MF0045 MF0055 click to enlarge Attached to ABS plastic RP series enclosure Use With Enclosure Part Numbers Smaller Enclosures - RP1025-RP1285 or RP1025C-RP1285C Larger Enclosures - RP1455-RP1456 or RP1455C-RP1465C Exactly what you are looking for??? Link to our stocking distributors - most have "on-line" pricing, stock check and ordering!!! Order from your favorite distributor HOME PAGE Copyright; © 2007-2009 Hammond Mfg Co Inc URL: http://www.hammondmfg.com
RP1285C 价格&库存
很抱歉,暂时无法提供与“RP1285C”相匹配的价格&库存,您可以联系我们找货
RP1285C
    • 1+159.70661
    库存:13
