1554D2GYCL
1554D2GYCL
    HAMMONDMANUFACTURING
    BOX PLSTC GRAY/CLR 4.72"LX2.56"W
1554D2GYCL 数据手册
120.00 [4.72] 54.50 [2.15] (INSIDE HEIGHT) B 3.00 [.12] 65.00 [2.56] 53.37 [2.10] 3.00 [.12] 53.91 [2.12] A A 57.41 [2.26] (INSIDE WIDTH) B SECTION B-B SIDE VIEW 60.50 [2.38] TOP VIEW 15.00 [.59] 2.50 [.10] 8.33 [.33] 82.30 [3.24] POLYCARBONATE VERSION ONLY UL O 16.66 45.00 [1.77] 52.83 [2.08] 112.91 [4.45] 6.00 [.24] C [.66] STEEL PANEL ORDER SEPARATELY 36.17 [1.42] SECTION A-A SIDE VIEW US LISTED Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 110.49 [4.35] (INSIDE LENGTH) ® FILE #E65324 NEMA 4, 4X N OTE P urc has ed as s em bly inc ludes box , lid, 4 c over s c rew s , and preform ed s ilic one gas k et. G eneral P urpos e A B S vers ion is not U L approved. (M atl U L94 - H B ) P oly c arbonate vers ion is U L 508 approved. (M atl U L94 - 5V A @ 3m m ) R e co mme n d e d C o v e r s cre w to rq u e -- 2.5 lb f-in (30 cN -m) 85.01 [3.35] 113.05 [4.45] 87.00 [3.43] 52.00 [2.05] 59.00 40.01 [2.32] [1.58] 14.00 [.55] 28.00 [1.10] 95.00 [3.74] Ge n e ral P u rp o se  A B S  R A L‐ 7035 P o ly carb o n ate  R A L‐ 7035 R7.50 [.30] 39.07 [1.54] 56.00 [2.20] 85.00 [3.35] 114.00 [4.49] INSIDE BOX 82.00 [3.23] M4 STAINLESS STEEL INSERTS 1554D GY 1554D 2GY 1554D C le a r / S m o ke L id En clo su re M3 BRASS INSERTS R6.00 [.24] 2X 4.00 [ 2X .16] MOUNTING HOLES ACCEPTS #6 SELF-TAPPING SCREW 1554D 1554D R e g u l a r En clo su re P o ly carb o n ate  B o x  /  C le ar P o ly carb o n ate  Lid P o ly carb o n ate  B o x  / S m o k e  P o ly carb o n ate  Lid 1554D 2GYC L 1554D 2GYS L A C C ES S O R IES S teel Inner P anels S teel P anel / P .C . B oard M ac hine S c rew [M 3 x 8m m P lated] S t eel P anel / P . C . B oard S elf Tapping S c rew [#6 X 1/4" (6.4m m ) P lated] C over S c rew s (P k g 4) [M 4 X 20m m S t ainles s S t eel] S ilic one P re-form ed G as k et B lac k 1554C P L 1591M M 100 1598A TS 100 S C 1554 1554C GA S K ET INSIDE LID Dimensions: mm [inches] 1554D www.hammondmfg.com ®
1554D2GYCL 价格&库存
很抱歉,暂时无法提供与“1554D2GYCL”相匹配的价格&库存,您可以联系我们找货
1554D2GYCL
  • 1+168.416081+21.11970
  • 10+142.2841110+17.84270
  • 50+130.9302250+16.41890
1554D2GYCL
    • 1+181.82560
    • 5+178.55565
    • 10+175.33778
    • 15+172.68225
    • 20+169.29775
    库存:2
