Top View of Assembly
End View of Assembly
240.0 mm
[9.45 in]
30.00 mm
[1.18 in]
229.78 mm
[9.05 in]
Inlay Length
A
A
179.78 mm
[7.08 in]
Inlay Width
190.0 mm
[7.48 in]
SECTION A-A
(Side View of Assembly)
23.25 mm
[.92 in]
Inner Height
54.2 mm
[2.13 in]
5.0 mm
[.20 in]
PCB Post Height
18.2 mm
[.72 in]
Battery Holder
Removable Panel
71.75 mm
[2.82 in]
End Panel
Inside View Top
120.0 mm
[4.72 in]
140.00 mm
[5.51 in]
59.5 mm
[2.34 in]
163.92 mm
[6.45 in]
166.30 mm
[6.55 in]
2.50 mm
[.10 in]
19.50 mm
[.77 in]
Bottom Inlay
50.0 mm x 50.0 mm
x 50.0 mm Depth
Inside View Bottom
55.00 mm
[2.17 in]
80.00 mm
[3.15 in]
.75 mm
[.03 in]
Top Inlay Depth
68.90 mm
[2.71 in]
Viewing Area
17.45 mm
[.69 in]
Viewing Area
134.13 mm
[5.28 in]
120.0 mm
[4.72 in]
60.0 mm
[2.36 in]
60.0 mm
[2.36 in]
Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.)
Contact Factory
mjm@hammondmfg.com for quotes
Solid models of this enclosure available in STEP or IGES.
NOTE
Enclosure molded from FR ABS (UL94-V0) plastic.
Purchased assembly includes top and bottom cover, 1 removable panel, battery
door, battery spring clips (8 pcs), 9V adapter (2 pcs) and 6 cover screws (M3-0.5 x
18mm) . M3 Brass inserts are installed for cover screws. (P.C. Board not supplied)
PART NUMBERS
1599TABLBAT Enclosure
Black Enclosure
1599TABLBKBAT
Grey Enclosure
1599TABLGYBAT
ACCESSORIES
131.92 mm
[5.19 in]
231.97 mm
[9.13 in]
Replacement Cover Screws (Pkg 100)
1594MS100 (Silver)
1594MS100BK (Black)
P.C. Board Screws
1593ATS50 (Pkg 50)
1593ATS100 (Pkg 100)
55.00 mm
[2.17 in]
Drawings available
for maximum P.C
Board size for top
and bottom
25.0 mm
[.98 in]
PCB Posts x 10
Accepts #4 x 1/4"
Self-Tapping Screw
100.0 mm
[3.94 in]
100.0 mm
[3.94 in]
1599TABLBAT
很抱歉,暂时无法提供与“1599TABLGYBAT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+261.742331+33.78577
