1590PGY
1590PGY
    HAMMONDMANUFACTURING
    BOX ALUM GRAY 6.02"L X 3.27"W
1590PGY 数据手册
153.20 [6.031] 45.40 [1.787] INSIDE HEIGHT 140.00 [5.512] A B B 83.10 [3.272] 70.00 [2.756] A TOP VIEW 5.50 [.217] 2.80 [.110] 73.98 [2.913] INSIDE WIDTH 50.40 [1.984] 41.73 [1.643] GUIDE HEIGHT SECTION A-A END VIEW 2.00 [.079] SLOT WIDTH Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 46.40 [1.827] 1.50 [.059] NOTE DETAIL C 2.20 [.087] 1.10 [.043] GUIDE DEPTH 146.29 [5.759] INSIDE LENGTH Purchased assembly includes box, lid and 4 cover screws. Box and lid are made from Diecast Aluminum Alloy. Silicone Gasket supplied with liquid resistant enclosure. Recommended Torque: 50-55 cN.m [71-78 ozf.in] Recommended Torque with Gasket : 25-30 cN.m [36-43 ozf.in] 3.00 [.118] GUIDE WIDTH PART NUMBERS 1590P Enclosure 1590P Natural Finish Enclosure 1590PBK Black Textured Enclosure 1590P Liquid Resistant Enclosure (Silicone Gasket) 1590W P Natural Finish Enclosure 1590W PBK Black Textured Enclosure ACCESSORIES SECTION B-B SIDE VIEW 144.48 [5.688] 130.48 [5.137] 4X 4.00 [.157] 74.38 [2.928] 4.26 [.168] C 148.60 [5.850] 134.20 [5.283] INSIDE BOX Stainless Steel Cover Screw s (Pkg 100) [M3.5 x 12mm, W ith O-Ring] 1550W MS100 Black Stainless Steel Cover Screw s (Pkg 100) [M3.5 x 12mm, W ith O-Ring] 1550W MS100BK Standard Cover Screws 78.50 [3.091] 60.34 [2.376] INSIDE LID Liquid Resistant Cover Screws 4X M3.5x0.6  3.90  2.70 64.20 [2.528] Dimensions: mm [inches] Plated Cover Screw s (Pkg 100) [M3.5 x 12mm] Black Cover Screw s (Pkg 100) [M3.5 x 12mm] 1550MS100 1550MS100BK 1590P www.hammondmfg.com ®
1590PGY
物料型号:1590P Enclosure
器件简介:该产品是一款由Hammond Manufacturing公司生产的金属外壳,具有自然表面和黑色纹理两种版本,以及具有液体防护功能的版本。
引脚分配:文档中未明确提供引脚分配信息。
参数特性:外壳尺寸为内部长度153.20mm x 宽度140.00mm x 高度45.40mm,外部尺寸为146.29mm x 130.48mm x 78.50mm。具有不同的安装孔和槽位尺寸,以及盖子和盒子的内部尺寸。
功能详解:外壳可以进行工厂修改,如铣削、钻孔、打印等。联系工厂邮箱mjm@hammondmfg.com获取报价。提供STEP或IGES格式的实体模型。
应用信息:适用于需要一定防护等级的电子设备。
封装信息:外壳和盖子采用压铸铝合金制成。液体防护型外壳配有硅胶垫圈,推荐的扭矩分别为25-30 cN.m和50-55 cN.m。
配件信息:包括标准盖螺丝、黑色盖螺丝、不锈钢盖螺丝(带O型圈)等。
1590PGY 价格&库存
很抱歉,暂时无法提供与“1590PGY”相匹配的价格&库存,您可以联系我们找货
