1599TABMBKBAT
1599TABMBKBAT
    HAMMONDMANUFACTURING
    BOXABSBLACK6.69"LX5.32"W
1599TABMBKBAT 数据手册
Top View of Assembly End View of Assembly 169.98 [6.69] 158.57 [6.24] (Inlay Length) 135.00 [5.31] 123.57 [4.86] (Inlay Width) A 27.00 [1.06] A SECTION A-A (Side View of Assembly) Removable Panel 65.10 [2.56] 18.70 [.74] .75 [.03] (Top Inlay Depth) 51.92 [2.04] 62.90 [2.48] 16.80 [.66] End Panel 20.75 [.82] (Inner Height) 18.25 [.72] 4.75 [.19] (PCB Post Height) 2.80 [.11] Bottom Inlay 44X33X0.5 mm 85.0 [3.35] 42.47 [1.67] PCB Posts x 6 Accepts #4 x 1/4" Self-Tapping Screw NOTE Inside View Top Inside View Bottom Enclosure molded from FR ABS (UL94-V0) plastic. Purchased assembly includes top and bottom cover, 1 removable panel, battery door, battery spring clips (8 pcs), 9V adapter (2 pcs) and 6 cover screws (M3-0.5 x 18mm) . M3 Brass inserts are installed for cover screws. (P.C. Board not supplied) 85.0 [3.35] 27.5 [1.08] 27.5 [1.08] PART NUMBERS 1599TABMBAT Enclosure Black Enclosure 113.94 [4.49] 79.94 [3.15] Drawings available for maximum P.C Board size for top and bottom 59.7 [2.35] 7.5 [.29] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 100.00 [3.94] 50.00 [1.97] 42.47 [1.67] 112.15 [4.42] 78.15 [3.08] PCB Posts x 8 Accepts #4 x 1/4" Self-Tapping Screw Grey Enclosure ACCESSORIES 161.46 [6.36] 77.0 [3.03] 75.0 [2.95] Dimensions: mm [inches] 1599TABMBKBAT 1599TABMGYBAT Replacement Cover Screws (Pkg 100) 1594MS100 (Silver) 1594MS100BK (Black) P.C. Board Screws 1593ATS50 (Pkg 50) 1593ATS100 (Pkg 100) 1599TABMBAT
1599TABMBKBAT 价格&库存
很抱歉,暂时无法提供与“1599TABMBKBAT”相匹配的价格&库存,您可以联系我们找货
1599TABMBKBAT
  • 1+237.220181+30.67586
  • 5+199.740115+25.82917
  • 10+185.6253710+24.00394
  • 25+168.5806825+21.79982
  • 50+156.7992950+20.27633
  • 100+145.89147100+18.86579
  • 250+144.15883250+18.64174
库存:1
1599TABMBKBAT
  • 1+32.193521+4.16307
库存:30
1599TABMBKBAT
  • 2+32.755042+4.23568
库存:30
