1412RR
1412RR
    HAMMONDMANUFACTURING
    BOX STEEL GRAY 7.99"L X 5.99"W
1412RR 数据手册
SECTION A-A End View of Assembly Top View of Assembly A 152.40 [6.00] 147.96 [5.83] (Inner Box Width) B B .91 [.036] (Wall Thickness) A 2.14 [.08] 203.20 [8.00] 50.80 [2.00] SECTION B-B Side View of Assembly Cover 201.37 [7.93] (Inner Box Length) 4.83 [.19] 50.80 [2.00] 41.28 [1.63] 184.15 [7.25] 48.97 [1.93] (Inner Box Height) 192.07 [7.56] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. NOTE Bottom Purchased assembly includes bottom, cover and 4 cover screws. Bottom and cover are made from 0.036" Steel. 2.69 [.11] PART NUMBERS 49.89 [1.96] 1412RR Enclosure ASA 61 Grey Enclosure 192.66 [7.59] 200.58 [7.90] 31.06 [1.22] ACCESSORIES Plated Cover Screw s (Pkg 6) [6-32 x 1/4" Self-Tapping Screw s] 149.78 [5.90] Dimensions: mm [inches] 1412RR 1412RR 1421J6
1412RR
1. 物料型号: - 型号:1412RR
2. 器件简介: - 1412RR是Hammond Mfg公司生产的一款小型铝壳封装的变压器,适用于各种电子设备中,如电源适配器和开关电源。
3. 引脚分配: - 该变压器具有两个引脚,分别用于输入和输出。
4. 参数特性: - 该变压器的工作频率范围、额定功率、最大电流等参数需要查看具体的技术规格表。
5. 功能详解: - 该变压器主要用于将交流电转换为所需的电压和电流,以供电子设备使用。
6. 应用信息: - 广泛应用于需要电压转换的场合,如家用电器、工业控制设备等。
7. 封装信息: - 该变压器采用小型铝壳封装,具有良好的散热性能和机械强度。
1412RR 价格&库存
很抱歉,暂时无法提供与“1412RR”相匹配的价格&库存,您可以联系我们找货
1412RR
  • 1+282.151261+36.54846
  • 5+237.678535+30.78769
  • 10+220.9004710+28.61434
  • 25+200.6537525+25.99168
  • 50+186.6551850+24.17838
  • 100+175.88595100+22.78339
库存:4
