1590Z060BK
1590Z060BK
    HAMMONDMANUFACTURING
    BOXALUMBLACK1.97"LX1.77"W
1590Z060BK 数据手册
50.20 [1.98] 25.40 [1.00] A 35.00 [1.38] B (INSIDE DEPTH) 39.28 [1.55] 45.20 [1.78] B (INSIDE WIDTH) A 30.40 [1.20] 40.00 [1.57] 6.20 [.24] TOP VIEW SECTION A-A END VIEW 1.50 [.06] ACCEPTS #6 SELF TAPPING GROUND SCREW 25.70 [1.01] 2.42 [.10] (AVERAGE WALL THICKNESS) 44.28 [1.74] (INSIDE LENGTH) 40.05 25.16 [1.58] [.99] 10.00 [.39] UL O 16.98 [.67] C 10.48 [.41] C Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. C (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE SECTION B-B SIDE VIEW ACCEPTS M4 - 0.7 MACHINE SCREW 41.99 27.49 [1.65] [1.08] Purchased assembly includes box, lid, silicone gasket, 2 cover screws and 1 ground screws Box and lid are made from Diecast Aluminum Alloy. 30.55 [1.20] Recommended cover screw Torque 5-7.5 lbf.in ( 50 -75 cN.m) 45.05 [1.77] 1590Z060 INSIDE BOX 1590Z060 Enclosure Basic Enclosure 22.49 [.89] 36.93 [1.45] 35.00 [1.38] 40.00 [1.57] INSIDE LID US LISTED ® FILE #E65324 NEMA 4, 4X 4.50 Black Enclosure Grey Enclosure - RAL7001 Gloss 5.20 [.20] 6.84 [.27] [.18] SECTION C-C MOUNTING HOLE 1590Z060 1590Z060BK 1590Z060GY ACCESSORIES Pre-Formed Silicone Gasket Plated Ground Hardware (6 Pack) [SCREW 6-32X1/4 PH TYPE C] 1590Z060G 3.82 [.15] 1421J6 ® Dimensions: mm [inches] 1590Z060 www.hammondmfg.com
1590Z060BK
1. 物料型号:1590Z060
2. 器件简介: - 该器件为Hammond Manufacturing生产的NEMA 4和4X®防护等级的箱体,适用于需要一定防护的应用场合。 - 箱体包括盒体、盖子、硅胶垫圈、2个盖子螺钉和1个接地螺钉。
3. 引脚分配: - 该箱体设计用于接受M4 - 0.7规格的机器螺钉。 - 提供有用于盖子安装的自攻接地螺钉。
4. 参数特性: - 箱体和盖子由压铸铝合金制成。 - 推荐盖子螺钉的扭矩为5-7.5 Ibf.in(50-75 cN.m)。 - 箱体内部尺寸为长40.05mm(1.58英寸),宽39.28mm(1.55英寸),高25.40mm(1.00英寸)。 - 盖子内部尺寸为长45.20mm(1.78英寸),宽35.00mm(1.38英寸)。
5. 功能详解: - 箱体设计用于保护内部元件免受尘埃、水和其他环境因素的影响。 - 可提供工厂修改服务,如铣削、钻孔、打印等,具体可联系工厂获取报价。 - 提供STEP或IGES格式的实体模型。
6. 应用信息: - 适用于需要NEMA 4和4X®防护等级的应用场合,如工业控制、电气设备等。
7. 封装信息: - 标准封装为黑色(1590Z060BK)、灰色RAL7001高光(1590Z060GY)。 - 可提供预成型硅胶垫圈(15902060G)和镀层接地硬件(6包装,型号1421J6)作为配件。
1590Z060BK 价格&库存
很抱歉,暂时无法提供与“1590Z060BK”相匹配的价格&库存,您可以联系我们找货
1590Z060BK
  • 1+183.70009
库存:55
