1554N2GYCL
1554N2GYCL
    HAMMONDMANUFACTURING
    BOX PLSTC GRAY/CLR 4.72"LX4.72"W
1554N2GYCL 数据手册
120.00 [4.72] 107.00 [4.21] 54.50 [2.15] (INSIDE HEIGHT) B 3.00 [.12] 120.00 [4.72] 112.91 [4.45] 3.00 [.12] 107.00 [4.21] A 108.91 [4.29] (INSIDE WIDTH) A B 15.00 [.59] TOP VIEW SECTION B-B SIDE VIEW 60.50 [2.38] 2.50 [.10] POLYCARBONATE VERSION ONLY UL O 91.03 [3.58] 45.00 [1.77] C 16.66 6.00 [.24] 112.91 [4.45] (INSIDE LENGTH) 87.30 [3.44] 19.38 [.76] 95.88 [3.77] 114.88 [4.52] STEEL PANEL ORDER SEPARATELY 67.92 [2.67] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) N OTE P urc has ed as s em bly inc ludes box , lid, 4 c over s c rews , and preform ed s ilic one gas k et. G eneral P urpos e A B S vers ion is not UL approved. (M atl UL94 - HB ) P oly c arbonate vers ion is UL 508 approved. (M atl UL94 - 5V A @ 3m m ) 87.00 [3.43] R e comme nde d C ov e r scre w torque -- 2.5 lbf-in (30 cN -m) 107.70 [4.24] 114.88 [4.52] 1554N 1554N Re gula r Enclosure 98.00 [3.86] 98.00 [3.86] 75.88 [2.99] US LISTED Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. [.66] SECTION A-A SIDE VIEW 107.00 [4.21] ® FILE #E65324 NEMA 4, 4X 4X 4.00 [4X .16] MOUNTING HOLES 28.00 [1.10] 56.00 [2.20] ACCEPTS #6 SELF-TAPPING SCREW INSIDE BOX M4 STAINLESS STEEL INSERTS 1554N GY 1554N 2GY 1554N Cle a r / S m oke Lid Enclosure Polycarbonate  Box / Cle ar Polycarbonate  Lid Polycarbonate  Box / Sm oke  Polycarbonate  Lid 1554N 2GYCL 1554N 2GYSL ACCES S O RIES S teel Inner P anels S teel P anel / P .C. B oard M ac hine S c rew [M 3 x 8m m P lated] S teel P anel / P .C. B oard S elf Tapping S c rew [#6 X 1/4" (6.4m m ) P lated] Cover S c rews (P k g 4) [M 4 X 20m m S tainles s S teel] S ilic one P re-form ed Gas k et B lac k 113.00 [4.45] 72.00 [2.83] M3 BRASS INSERTS Ge ne ral Purpose  ABS RAL‐7035 Polycarbonate  RAL‐7035 111.00 [4.37] 92.00 [3.62] 1554N PL 1591MM100 1598ATS100 SC1554 1554N GASKET R7.50 [.30] INSIDE LID Dimensions: mm [inches] 1554N www.hammondmfg.com ®
1554N2GYCL 价格&库存
很抱歉,暂时无法提供与“1554N2GYCL”相匹配的价格&库存,您可以联系我们找货
1554N2GYCL
    • 1+180.92578
    • 5+176.41985
    • 10+172.00505
    • 15+167.70163
    • 20+163.51972
    库存:1
    1554N2GYCL
    • 1+171.502521+20.49820
    • 10+142.9502810+17.08560
    • 50+133.4013550+15.94430
    库存:6
