1456CE3BKBU
1456CE3BKBU
    HAMMONDMANUFACTURING
    CONSOLE ALUMINUM 4.18"L X 5.75"W
1456CE3BKBU 数据手册
8 7 6 5 6.35 mm [0.250 in] 3.18 mm [0.125 in] 101.60 mm [4.000 in] 15.88 mm [0.625 in] D 22.23 mm [0.875 in] A 57.13 mm [2.249 in] 28.39 mm [1.118 in] R2.44 mm [0.096 in] D 111.13 mm [4.375 in] 61.14 mm [2.407 in] R4.76 mm [0.188 in] mm ] .56 in 97 .841 [3 C R6.35 mm [0.250 in] 76.67 mm [3.019 in] C 30.0° 31.92 mm [1.257 in] 22.23 mm [0.875 in] 6.35 mm [0.250 in] ASSEMBLY - SIDE VIEW (OPEN) Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. ASSEMBLY - REAR VIEW (OPEN) 128.60 mm [5.063 in] 119.05 mm [4.687 in] 122.56 mm [4.825 in] 128.57 mm [5.062 in] n2.79 mm 8X [0.110 in] 18.19 mm [0.716 in] 146.05 mm [5.750 in] DETAIL B B 80.98 mm [3.188 in] 139.70 mm [5.500 in] 14.29 mm [0.563 in] 1 25.54 mm [1.006 in] 136.45 mm [5.372 in] B 2 72.95 mm [2.872 in] 46.81 mm [1.843 in] 102.11 mm [4.020 in] 3 mm ] .09 in 95 .744 [3 30.0° DETAIL A 76.20 mm [3.000 in] 4 80.95 mm [3.187 in] 38.10 mm [1.500 in] 25.40 mm [1.000 in] 3.18 mm [0.125 in] B 1456C E 3 B e ig e Top, B lue C as e - 1456C E3W H B U B la ck Top, B lue C as e - 1456C E3B K B U E nc los ure C as e - 12 ga. A lum inum Top P anel S iz es to 14" W ide - 14 ga. A lum inum S elf A dhes ive R ubber F eet Inc luded R eguired H ardw are Inc luded R eplac em ent S c rew s - 1421-J6 (6 pc s .) 106.22 mm [4.182 in] 90.17 mm [3.550 in] A TOP PANEL - BOTTOM VIEW 8 7 n4.80 mm 4X A 6 5 1456CE3 n4.34 mm 4X ENCLOSURE CASE - BOTTOM [0.189 in] [0.171 in] 4 3 2 1
1456CE3BKBU 价格&库存
很抱歉,暂时无法提供与“1456CE3BKBU”相匹配的价格&库存,您可以联系我们找货
1456CE3BKBU
  • 1+267.504681+34.74750
  • 10+222.8770710+28.95060
  • 50+208.0012050+27.01830
