1590WNFBK
1590WNFBK
    HAMMONDMANUFACTURING
    BOX ALUM BLACK 4.72"L X 2.58"W
1590WNFBK 数据手册
121.20 [4.772] 51.49 [2.027] 146.05 [5.750] 35.20 [1.386] INSIDE HEIGHT 110.00 [4.331] A 65.50 [2.579] 55.50 [2.185] B B 57.21 [2.252] INSIDE WIDTH A 41.50 [1.634] TOP VIEW 5.50 [.217] SECTION A-A END VIEW 2.90 [.114] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 2.01 [.079] SLOT WIDTH 36.00 [1.417] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Purchased assembly includes box, lid and 4 cover screws. Box and lid are made from Diecast Aluminum Alloy. Silicone Gasket supplied with liquid resistant enclosure. Bottom Flange is W elded. DETAIL C 1.50 [.059] SLOT DEPTH 3.40 [.134] 113.11 [4.453] INSIDE LENGTH 3.00 [.118] GUIDE WIDTH Recommended Torque: 50-55 cN.m [71-78 ozf.in] Recommended Torque with Gasket : 25-30 cN.m [36-43 ozf.in] PART NUMBERS 1590NF Enclosure 1590NF Natural Finish Enclosure 1590NFBK Black Textured Enclosure 1590NF Liquid Resistant Enclosure (Silicone Gasket) 1590W NF Natural Finish Enclosure 1590W NFBK Black Textured Enclosure ACCESSORIES SECTION B-B SIDE VIEW 112.91 [4.445] 4X M3.5x0.60.51  0.16  0.02 98.56 [3.880] Liquid Resistant Cover Screws 104.10 [4.098] Stainless Steel Cover Screw s (Pkg 100) [M3.5 x 12mm, W ith O-Ring] Black Stainless Steel Cover Screw s (Pkg 100) [M3.5 x 12mm, W ith O-Ring] C 1550W MS100 1550W MS100BK Standard Cover Screws 3.90 [.154] 44.10 [1.736] 4X 4.00 [.157] INSIDE LID 57.70 [2.272] 9.53 [.375] 3.96 [.156] 62.00 [2.441] 49.00 40.01 [1.929] [1.575] 117.70 [4.634] 134.77 [5.306] INSIDE BOX Dimensions: mm [inches] Plated Cover Screw s (Pkg 100) [M3.5 x 12mm] Black Cover Screw s (Pkg 100) [M3.5 x 12mm] 1550MS100 1550MS100BK 1590NF www.hammondmfg.com ®
1590WNFBK 价格&库存
很抱歉,暂时无法提供与“1590WNFBK”相匹配的价格&库存,您可以联系我们找货
1590WNFBK
  • 1+296.767091+35.47867
  • 5+253.636615+30.32240
  • 10+237.0257810+28.33657
  • 25+216.7285525+25.91002
  • 50+203.4782650+24.32594
库存:2
