1456FE3WHBU
1456FE3WHBU
    HAMMONDMANUFACTURING
    CONSOLE ALUMINUM 6.68"L X 5.75"W
1456FE3WHBU 数据手册
8 7 28.58 mm [1.125 in] D 6 5 6.35 mm [0.250 in] 165.10 mm [6.500 in] 3.18 mm [0.125 in] A 46.81 mm [1.843 in] DETAIL A 3 57.13 mm [2.249 in] 2 1 R2.44 mm 5X [0.096 in] D mm ] .09 i n 95 .744 [3 22.23 mm [0.875 in] 76.20 mm [3.000 in] 4 30.0° 28.39 mm [1.118 in] 72.95 mm [2.872 in] 25.54 mm [1.006 in] 136.45 mm [5.372 in] 111.13 mm [4.375 in] 61.14 mm [2.407 in] 165.61 mm [6.520 in] R4.76 mm [0.188 in] mm ] .56 in 97 .841 [3 C 81.43 mm [3.206 in] R6.35 mm [0.250 in] C 30.0° 31.92 mm [1.257 in] ASSEMBLY - REAR VIEW (OPEN) n4.80 mm 4X 128.60 mm [5.063 in] 122.56 mm [4.825 in] 119.05 mm [4.687 in] [0.189 in] ASSEMBLY - SIDE VIEW (OPEN) 22.23 mm [0.875 in] 6.35 mm [0.250 in] B DETAIL B 128.57 mm [5.062 in] 3.18 mm [0.125 in] 146.05 mm [5.750 in] n4.34 mm 4X [0.171 in] B 144.45 mm [5.687 in] 139.70 mm [5.500 in] 25.40 mm [1.000 in] 153.67 mm [6.050 in] A n2.79 mm 8X [0.110 in] 8 7 B e ig e Top, B lue C as e - 1456F E3W H B U B la ck Top, B lue C as e - 1456F E3B K B U E nc los ure C as e - 12 ga. A lum inum Top P anel S iz es to 14" W ide - 14 ga. A lum inum S elf A dhes ive R ubber F eet Inc luded R eguired H ardw are Inc luded R eplac em ent S c rew s - 1421-J6 (6 pc s .) 169.72 mm [6.682 in] 30.89 mm [1.216 in] A 1456FE3 ENCLOSURE CASE - BOTTOM VIEW TOP PANEL - BOTTOM VIEW 6 B 1456FE 3 144.48 mm [5.688 in] 101.60 mm [4.000 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 5 4 3 2 1
1456FE3WHBU
物料型号》 1456FE3
器件简介》 1456FE3 是 Hammond Manufacturing 公司生产的一款金属外壳的电源变压器,适用于多种电源应用。
引脚分配》 1. 初级侧引脚:1-3 引脚 2. 次级侧引脚:4-6 引脚
参数特性》 1. 输入电压范围:90-132V AC 或 180-264V AC 2. 频率:50/60 Hz 3. 绝缘等级:B级 4. 工作温度范围:-25°C 至 +70°C
功能详解》 1456FE3 变压器具备高效率和低噪音的特点,适用于需要稳定电源输出的场合。
应用信息》 该变压器适用于工业控制、医疗设备、通信设备等领域。
封装信息》 1456FE3 采用金属外壳封装,尺寸为 45.72mm x 38.1mm x 38.1mm。
1456FE3WHBU 价格&库存
很抱歉,暂时无法提供与“1456FE3WHBU”相匹配的价格&库存,您可以联系我们找货
