1456FE2WHBU
1456FE2WHBU
    HAMMONDMANUFACTURING
    CONSOLE ALUMINUM 6.68"L X 5.77"W
1456FE2WHBU 数据手册
8 7 6 5 6.35 mm [0.250 in] D 22.23 mm [0.875 in] A 50.80 mm [2.000 in] 21.41 mm [0.843 in] DETAIL A 9 mm 85.4 66 in] [3.3 15.0° 28.19 mm [1.110 in] 25.08 mm [0.987 in] 136.86 mm [5.388 in] 165.61 mm [6.520 in] 3 mm 84.0 08 in] [3.3 R6.35 mm [0.250 in] C 56.03 mm [2.206 in] ASSEMBLY - REAR VIEW (OPEN) 129.01 mm [5.079 in] n4.80 mm 4X [0.189 in] 119.46 mm [4.703 in] 3 57.15 mm [2.250 in] D R2.44 mm 5X [0.096 in] 47.55 mm [1.872 in] 111.53 mm [4.391 in] 55.82 mm [2.198 in] R4.76 mm [0.188 in] 15.0° C ASSEMBLY - SIDE VIEW (OPEN) 6.35 mm [0.250 in] 122.96 mm [4.841 in] 128.98 mm [5.078 in] DETAIL B 3.18 mm [0.125 in] 146.46 mm [5.766 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. B B 101.60 mm [4.000 in] 140.11 mm [5.516 in] 144.45 mm [5.687 in] 25.40 mm [1.000 in] 12.70 mm [0.500 in] 144.48 mm [5.688 in] A A TAP PANEL - BOTTOMW VIEW 8 B 1456FE 2 B e ig e Top, B lue C as e - 1456F E2W H B U B la ck Top, B lue C as e - 1456F E2B K B U E nc los ure C as e - 12 ga. A lum inum Top P anel S iz es to 14" W ide - 14 ga. A lum inum S elf A dhes ive R ubber F eet Inc luded R eguired H ardw are Inc luded R eplac em ent S c rew s - 1421-J6 (6 pc s .) 169.72 mm [6.682 in] 18.19 mm [0.716 in] 14.29 mm [0.563 in] 1 32.01 mm [1.260 in] 22.23 mm [0.875 in] 153.67 mm [6.050 in] 2 3.18 mm [0.125 in] 165.10 mm [6.500 in] 28.58 mm [1.125 in] 4 7 n2.79 mm 8X [0.110 in] 6 1456FE2 ENCLOSURE CASE - BOTTOM VIEW 5 4 3 2 1
1456FE2WHBU 价格&库存
很抱歉,暂时无法提供与“1456FE2WHBU”相匹配的价格&库存,您可以联系我们找货
1456FE2WHBU
库存:1
