1456FE1WHBU
1456FE1WHBU
    HAMMONDMANUFACTURING
    CONSOLE ALUMINUM 6.68"L X 5.77"W
1456FE1WHBU 数据手册
8 7 6 5 4 165.10 mm [6.500 in] 28.58 mm [1.125 in] A 6.35 mm [0.250 in] 3.18 mm [0.125 in] 165.61 mm [6.520 in] 57.47 mm [2.263 in] 34.43 mm [1.355 in] 37.62 mm [1.481 in] 33.58 mm [1.322 in] 136.86 mm [5.388 in] 111.53 mm [4.391 in] mm 144.77 in] [5.700 22.23 mm [0.875 in] 1 D 10.0° 62.35 mm [2.455 in] 2 R2.44 mm 4X [0.096 in] mm 140.75 in] [5.541 D C 3 R6.35 mm 2X [0.250 in] 10.0° 65.84 mm [2.592 in] DETAIL A C 39.99 mm [1.574 in] 22.23 mm [0.875 in] ASSEMBLY - REAR VIEW (OPEN) 129.01 mm [5.079 in] n4.80 mm 4X [0.189 in] 119.46 mm [4.703 in] 122.96 mm [4.841 in] ASSEMBLY - SIDE VIEW (OPEN) 6.35 mm [0.250 in] 3.18 mm [0.125 in] 146.46 mm [5.766 in] DETAIL B 128.98 mm [5.078 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. B n4.34 mm 4X B 140.11 mm [5.516 in] 14.29 mm [0.563 in] 169.72 mm [6.682 in] 101.60 mm [4.000 in] 144.45 mm [5.687 in] 144.48 mm [5.688 in] B 1456FE 1 [0.171 in] 153.67 mm [6.050 in] 25.40 mm [1.000 in] B e ig e Top, B lue C as e - 1456F E1W H B U B la ck Top, B lue C as e - 1456F E1B K B U E nc los ure C as e - 12 ga. A lum inum Top P anel S iz es to 14" W ide - 14 ga. A lum inum S elf A dhes ive R ubber F eet Inc luded R eguired H ardw are Inc luded R eplac em ent S c rew s - 1421-J6 (6 pc s .) 11.84 mm [0.466 in] A A TOP PANEL - BOTTOM VIEW 8 7 n2.79 mm 8x [0.110 in] 6 1456FE1 ENCLOSURE CASE - BOTTOM VIEW 5 4 3 2 1
1456FE1WHBU 价格&库存
很抱歉,暂时无法提供与“1456FE1WHBU”相匹配的价格&库存,您可以联系我们找货
1456FE1WHBU
  • 1+317.518831+40.72520
  • 10+264.6577610+33.94520
  • 50+246.9493050+31.67390
库存:2
