1554U2GY
1554U2GY
    HAMMONDMANUFACTURING
    BOX PLASTIC GRAY 7.87"L X 4.72"W
1554U2GY 数据手册
200.00 [7.87] 84.50 [3.33] 187.00 [7.36] (INSIDE HEIGHT) B 3.00 [.12] 3.00 [.12] 120.00 [4.72] 107.00 [4.21] A 112.13 [4.41] 108.13 [4.26] A (INSIDE WIDTH) B TOP VIEW 15.00 [.59] 90.50 [3.56] SECTION B-B SIDE VIEW 171.40 [6.75] POLYCARBONATE VERSION ONLY UL O C 2.00 [.08] 75.50 [2.97] 19.69 [.78] ® US LISTED FILE #E65324 NEMA 4, 4X [.75] 67.23 [2.65] STEEL PANEL ORDER SEPARATELY 106.60 [4.20] 192.13 [7.56] 6.00 [.24] 19.05 Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) N OTE (INSIDE LENGTH) SECTION A-A SIDE VIEW P urc has ed as s em bly inc ludes box , lid, 4 c over s c rew s , and preform ed s ilic one gas k et. G eneral P urpos e A B S vers ion is not U L approved. (M atl U L94 - H B ) P oly c arbonate vers ion is U L 508 approved. (M atl U L94 - 5V A @ 3m m ) 190.45 [7.50] R e co mme n d e d C o v e r scre w to rq u e -- 2.5 lb f-in (30 cN -m) 194.88 [7.67] 1554U 187.00 175.88 [7.36] [6.92] 161.50 4X 4.00 [4X .16] MOUNTING HOLES [6.36] 90.00 75.88 [3.54] [2.99] 114.88 87.00 [4.52] [3.43] 176.00 [6.93] 45.00 [1.77] ACCEPTS #6 SELF-TAPPING SCREW M3 BRASS INSERTS INSIDE BOX 1554U R e g u la r En clo su re 191.00 [7.52] Ge n e ral P u rp o se  A BS  RA L‐7035 P o ly carb o n ate  RA L‐7035 172.00 [6.77] 113.00 [4.45] 72.00 [2.83] M4 STAINLESS STEEL INSERTS 1554UGY 1554U2GY 1554U C le a r / S m o ke L id En clo su re P o ly carb o n ate  Bo x  / C le ar P o ly carb o n ate  Lid P o ly carb o n ate  Bo x  / S m o ke  P o lycarb o n ate  Lid A C C ES S O R IES S teel Inner P anels S teel P anel / P .C . B oard M ac hine S c rew [M 3 x 8m m P lated] S teel P anel / P .C . B oard S elf Tapping S c rew [#6 X 1/4" (6.4m m ) P lated] C over S c rew s (P k g 4) [M 4 X 20m m S tainles s S teel] S ilic one P re-form ed G as k et B lac k R7.50 [.30] INSIDE LID Dimensions: mm [inches] 1554U2GYC L 1554U2GYS L 1554UP L 1591M M100 1598A TS 100 S C 1554 1554UGA S K ET 1554U www.hammondmfg.com ®
1554U2GY 价格&库存
很抱歉,暂时无法提供与“1554U2GY”相匹配的价格&库存,您可以联系我们找货
1554U2GY
  • 1+266.679191+34.56670
  • 10+222.3053110+28.81500
  • 50+207.3977850+26.88270
1554U2GY
    • 1+246.37056
    • 5+241.93427
    • 10+237.58128
    • 15+233.65527
    • 20+229.79173
    库存:11
