1456FH2WHBU
1456FH2WHBU
    HAMMONDMANUFACTURING
    CONSOLE ALUMINUM 6.68"L X 8.77"W
1456FH2WHBU 数据手册
8 7 6 5 6.35 mm [0.250 in] D 4 A 21.41 mm [0.843 in] 133.35 mm [5.250 in] 9 mm 85.4 66 in] [ 3. 3 DETAIL A 15.0° 187.73 mm [7.391 in] 213.06 mm [8.388 in] 165.61 mm [6.520 in] R4.76 mm [0.188 in] 32.01 mm [1.260 in] 22.23 mm [0.875 in] ASSEMBLY - SIDE VIEW (OPEN) 6.35 mm [0.250 in] 195.66 mm [7.703 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 222.66 mm [8.766 in] 205.21 mm [8.079 in] 199.16 mm [7.841 in] 3.18 mm [0.125 in] DETAIL B 205.18 mm [8.078 in] B 12.70 mm [0.500 in] 216.31 mm [8.516 in] A 144.45 mm [5.687 in] 144.48 mm [5.688 in] 153.67 mm [6.050 in] 14.29 mm [0.563 in] B 1456FH2 25.40 mm [1.000 in] 101.60 mm [4.000 in] C 15.0° 56.03 mm [2.206 in] ASSEMBLY - END VIEW (OPEN) 136.78 mm [5.385 in] 1 mm 87.9 61 in] [3.4 R6.35 mm [0.250 in] R2.44 mm 5X [0.096 in] 47.55 mm [1.872 in] 28.19 mm [1.110 in] 50.80 mm [2.000 in] B [0.189 in] 1 D 22.23 mm [0.875 in] 28.58 mm [1.125 in] n4.80 mm 4X 2 3.18 mm [0.125 in] 165.10 mm [6.500 in] C 3 B e ig e Top, B lue C as e - 1456F H 2W H B U B la ck Top, B lue C as e - 1456F H 2B K B U E nc los ure C as e - 12 ga. A lum inum Top P anel S iz es to 14" W ide - 14 ga. A lum inum S elf A dhes ive R ubber F eet Inc luded R eguired H ardw are Inc luded R eplac em ent S c rew s - 1421-J6 (6 pc s .) 169.72 mm [6.682 in] 18.19 mm [0.716 in] A TOP PANEL - BOTTOM VIEW 8 7 n2.79 mm 8X [0.110 in] 6 n4.34 mm 4X [0.171 in] 1456FH2 ENCLOSURE CASE - BOTTOM VIEW 5 4 3 2 1
1456FH2WHBU
- 物料型号:1456FH2 - 器件简介:文档没有提供详细的器件简介,但根据提供的尺寸和材料信息,这似乎是一个铝制的机壳或外壳,适用于某些电子设备。 - 引脚分配:文档中没有提供关于引脚分配的信息。 - 参数特性:文档提供了一些尺寸参数,例如6.35 mm [0.250 in],165.10 mm [6.500 in],以及材料信息,如12 ga. Aluminum(12号铝)。 - 功能详解:文档没有提供功能详解,但提到了机壳可以进行工厂修改,例如铣削、钻孔、打印等。 - 应用信息:文档提及了机壳的尺寸范围和材料,暗示了其可能用于需要特定尺寸和强度的电子设备。 - 封装信息:文档提供了机壳的尺寸和材料信息,例如顶部面板尺寸可达到14英寸宽,使用14号铝材料。
1456FH2WHBU 价格&库存
很抱歉,暂时无法提供与“1456FH2WHBU”相匹配的价格&库存,您可以联系我们找货
1456FH2WHBU
  • 1+351.526121+45.08700
  • 10+292.9384310+37.57250
  • 50+273.3798450+35.06390
