1590Z120GY
1590Z120GY
    HAMMONDMANUFACTURING
    BOX ALUM GRAY 4.91"L X 3.14"W
1590Z120GY 数据手册
125.40 [4.94] A 50.80 [2.00] 113.00 [4.45] (INSIDE DEPTH) 70.64 [2.78] 80.40 [3.17] B 68.00 [2.68] B (INSIDE WIDTH) A TOP VIEW 58.80 [2.31] SECTION A-A END VIEW 15.60 [.61] 113.39 [4.46] 1.50 [.06] 6.00 [.24] 3.81 [.15] (AVERAGE WALL THICKNESS) 98.22 [3.87] 44.70 [1.76] 4.61 [.18] 44.20 [1.74] 68.39 [2.69] 68.00 [2.68] 116.04 [4.57] 3.60 113.00 [4.45] SECTION B-B SIDE VIEW ® US LISTED FILE #E65324 NEMA 4, 4X Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. NOTE [.14] Purchased assembly includes box, lid, silicone gasket, 4 cover screws and 2 ground screws with washers. Box and lid are made from Diecast Aluminum Alloy. INSIDE LID ACCEPTS M4 - 0.7 MACHINE SCREW 101.05 [3.98] ACCEPTS M4 MACHINE GROUND SCREW 1590Z120 1590Z120 Enclosure Basic Enclosure Black Enclosure 113.00 [4.45] 13.40 [.53] 24.00 [.94] Recommended cover screw Torque 5-7.5 lbf.in ( 50 -75 cN.m) 117.25 [4.62] C 6.94 [.27] UL O C (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) (INSIDE LENGTH) 4.06 [.16] 97.20 [3.83] Grey Enclosure - RAL7001 Gloss 52.00 [2.05] 72.25 [2.84] 48.05 [1.89] 1590Z120 1590Z120BK 1590Z120GY ACCESSORIES Steel Inner Panel 1590Z120PL Pre-Formed Silicone Gasket Copper Ground Hardware (2 Pack) [M4 - 0.7 X 6mm / M4 Washer] 1590Z120G SCGM4 15.00 [.59] 12.70 [.50] SECTION C-C MOUNTING HOLE DRAWINGS AVALIBLE FOR STEEL INNER PANEL 106.00 [4.17] C INSIDE BOX ® Dimensions: mm [inches] 1590Z120 www.hammondmfg.com
1590Z120GY 价格&库存
很抱歉,暂时无法提供与“1590Z120GY”相匹配的价格&库存,您可以联系我们找货
1590Z120GY
  • 1+300.08513
库存:31
