1456FH3BKBU
1456FH3BKBU
    HAMMONDMANUFACTURING
    CONSOLE ALUMINUM 6.68"L X 8.61"W
1456FH3BKBU 数据手册
8 7 6 5 6.35 mm [0.250 in] 57.15 mm [2.250 in] 22.23 mm [0.875 in] A 76.20 mm [3.000 in] 5 mm 160.209 in] [6.3 15.0° DETAIL A 34.23 mm [1.348 in] 46.81 mm [1.843 in] 165.61 mm [6.520 in] C 81.43 mm [3.206 in] 195.17 mm [7.684 in] 191.67 mm [7.546 in] B R2.44 mm 5X [0.096 in] D 183.74 mm [7.234 in] 61.70 mm [2.429 in] R4.76 mm [0.188 in] C 15.0° 38.36 mm [1.510 in] 22.23 mm [0.875 in] 3.18 mm [0.125 in] 6.35 mm [0.250 in] ASSEMBLY - SIDE VIEW (OPEN) 218.67 mm [8.609 in] DETAIL B 201.19 mm [7.921 in] n4.34 mm 4X Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. [0.171 in] B 153.67 mm [6.050 in] 101.60 mm [4.000 in] 212.32 mm [8.359 in] 144.45 mm [5.687 in] 25.40 mm [1.000 in] 144.48 mm [5.688 in] A [0.110 in] 8 TOP PANEL - BOTTOM VIEW 7 n4.80 mm 4X [0.189 in] 6 B 1456FH3 B e ig e Top, B lue C as e - 1456F H 3W H B U B la ck Top, B lue C as e - 1456F H 3B K B U E nc los ure C as e - 12 ga. A lum inum Top P anel S iz es to 14" W ide - 14 ga. A lum inum S elf A dhes ive R ubber F eet Inc luded R eguired H ardw are Inc luded R eplac em ent S c rew s - 1421-J6 (6 pc s .) 25.40 mm [1.000 in] 169.72 mm [6.682 in] 11.84 mm [0.466 in] n2.79 mm 8X 1 72.95 mm [2.872 in] m 51 m 161. 59 in] [6.3 R6.35 mm [0.250 in] 201.22 mm [7.922 in] 2 31.12 mm [1.225 in] 209.07 mm [8.231 in] ASSEMBLY - REAR VIEW (OPEN) 3 3.18 mm [0.125 in] 165.10 mm [6.500 in] 28.58 mm [1.125 in] D 4 A 1456FH3 ENCLOSURE CASE - BOTTOM VIEW 5 4 3 2 1
1456FH3BKBU 价格&库存
很抱歉,暂时无法提供与“1456FH3BKBU”相匹配的价格&库存,您可以联系我们找货
1456FH3BKBU
  • 1+306.309641+39.75340
  • 10+282.1914610+36.62330
库存:1
