1456KE3BKBU
1456KE3BKBU
    HAMMONDMANUFACTURING
    CONSOLE ALUM 10.18"L X 5.75"W
1456KE3BKBU 数据手册
8 7 15.88 mm [0.625 in] 6 5 4 254.00 mm [10.000 in] 57.13 mm [2.249 in] mm ] .09 in 95 .744 [3 D 76.20 mm [3.000 in] 46.81 mm [1.843 in] 6.35 mm [0.250 in] 254.51 mm [10.020 in] 136.45 mm [5.372 in] 22.23 mm [0.875 in] 81.43 mm [3.206 in] n4.80 mm 4X [0.189 in] 119.05 mm [4.687 in] R2.44 mm 5X [0.096 in] 72.95 mm [2.872 in] mm ] .56 in 97 .841 [3 111.13 mm [4.375 in] 61.14 mm [2.407 in] R4.76 mm [0.188 in] 30.0° DETAIL A C 31.92 mm [1.257 in] ASSEMBLY - SIDE VIEW (OPEN) ASSEMBLY - REAR VIEW (OPEN) 128.60 mm [5.063 in] 22.23 mm [0.875 in] 3.18 mm [0.125 in] 122.56 mm [4.825 in] 128.57 mm [5.062 in] 146.05 mm [5.750 in] n4.34 mm 4X [0.171 in] 6.35 mm [0.250 in] B 139.70 mm [5.500 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. DETAIL B 190.50 mm [7.500 in] 14.29 mm [0.563 in] 233.35 mm [9.187 in] B 233.38 mm [9.188 in] 25.40 mm [1.000 in] 242.57 mm [9.550 in] A B 1456K E 3 B e ig e Top, B lue C as e - 1456K E3W H B U B la ck Top, B lue C as e - 1456K E3B K B U E nc los ure C as e - 12 ga. A lum inum Top P anel S iz es to 14" W ide - 14 ga. A lum inum S elf A dhes ive R ubber F eet Inc luded R eguired H ardw are Inc luded R eplac em ent S c rew s - 1421-J6 (6 pc s .) 258.62 mm [10.182 in] 18.19 mm [0.716 in] n2.79 mm 8X [0.110 in] 7 A 1456KE3 ENCLOSURE CASE - BOTTOM VIEW TOP PANEL - BOTTOM ENCLOSURE 8 1 28.39 mm [1.118 in] 3.18 mm [0.125 in] C 2 D 25.54 mm 30.0° [1.006 in] A 3 6 5 4 3 2 1
1456KE3BKBU 价格&库存
很抱歉,暂时无法提供与“1456KE3BKBU”相匹配的价格&库存,您可以联系我们找货
