1590ZGRP083
1590ZGRP083
    HAMMONDMANUFACTURING
    Box Plastic, Fiberglass/Polyester Gray Cover Included 6.299" L x 2.953" W (159.99mm x 75.01mm) X 2.1...
1590ZGRP083 数据手册
47.50 [1.87] 160.00 [6.30] B (INSIDE HEIGHT) 148.00 [5.83] 63.00 [2.48] A A 4.28 [.17] 65.61 [2.58] 3.70 [.15] 75.00 [2.95] B TOP VIEW (INSIDE WIDTH) 55.00 [2.17] SECTION B-B END VIEW 11.30 [.44] 1.50 [.06] 5.50 [.22] 15.00 [.59] 40.50 [1.59] 150.71 [5.93] 148.50 [5.85] 133.50 [5.26] 30.00 [1.18] SECTION A-A SIDE VIEW UL O 5.00 STEEL INNER PANEL SOLD SEPERATLY 16.50 [.65] (INSIDE LENGTH) 139.00 [5.47] C [.20] 63.00 [2.48] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 7.50 [.30] 147.20 [5.80] 28.29 [1.11] ACCEPTS M4 x 0.7 SCREW 61.50 [2.42] INSIDE LID NOTE 150.71 [5.93] 148.00 134.71 [5.83] [5.30] 131.70 [5.19] 7.60 [.30] C 8.50 [.33] C 4.80 [.19] SECTION C-C MOUNTING HOLES US LISTED ® FILE #E65324 NEMA 4, 4X Purchased assembly includes Box, Lid, Gasket and 4 cover screws Enclosure Molded from Glass Reinforced Polyester Screw Should Not be Torqued Past 6-7.5 lbf.in (70-85 cN.m) 32.28 [1.27] PART NUMBERS 45.00 [1.77] 1590ZGRP083 Enclosure Grey Enclosure 64.62 [2.54] ACCESSORIES Copper Ground Hardware (2 Pack) [M4 - 0.7 X 6mm / M4 Washer] 1590ZGRP083GY SCGM4 Steel Inner Panel 1590ZGRP083PL Hinge Kit (2 Pack) 1427HK ACCEPTS M4x0.7 SCREW INSIDE BOX ® Dimensions: mm [inches] 1590ZGRP083 www.hammondmfg.com
1590ZGRP083
1. 物料型号: - 型号:1590ZGRP083 - 灰色型号:1590ZGRP083GY
2. 器件简介: - 该器件为NEMA 4, 4X美国列表的外壳,由玻璃增强聚酯材料制成,可接受M4 x 0.7的螺丝。
3. 引脚分配: - 该外壳接受M4 x 0.7的螺丝。
4. 参数特性: - 螺丝不应超过6-7.5 Ibf.in(70-85 cN.m)的扭矩。 - 尺寸:包括多种尺寸,例如147.20mm x 5.80英寸,131.70mm x 5.19英寸等。
5. 功能详解: - 外壳可以工厂修改(铣削、钻孔、印刷等),具体请联系工厂获取报价。 - 提供STEP或IGES格式的实体模型。
6. 应用信息: - 购买的组装包括箱体、盖子、垫圈和4个盖子螺丝。
7. 封装信息: - 配件包括铜接地硬件(2包)[M4 - 0.7 x 6mm/ M4垫圈],型号为SCGM4。 - 钢内面板型号为1590ZGRP083PL。 - 铰链套件(2包)型号为1427HK。
1590ZGRP083 价格&库存
很抱歉,暂时无法提供与“1590ZGRP083”相匹配的价格&库存,您可以联系我们找货
1590ZGRP083
  • 1+297.191681+38.52170
  • 10+247.6742710+32.10330
  • 50+231.1975250+29.96760
