7x6x2 DCE
Die-Cast Enclosure Antennas
e
The DCE series die cast aluminum enclosures from Laird are designed for extremely long life in
outdoor environments. The powder coat paint over aluminum construction offers unsurpassed
resistance to corrosion. The pole mount hardware includes heavy galvanized pole clamps and
stainless steel U bolts and attachment nuts. The die cast enclosure has extra heavy duty mounting
flanges for reliable mounting to poles or surface mounting to walls. The most unique feature is the
inclusion of 7 engineered hole knockouts which allow for many different configurations of connectors
and feedthru’s without the need for drilling holes. The knockouts are easily removed using a flat
blade screwdriver and hammer. The enclosures have Qty 4 threaded ¼” tall standoffs in the base for
mounting a user plate (included), which in turn can hold the users electronics. This configuration
provides universal mounting which is fully customizable by the user.
FEATURES
MARKETS
• Die cast aluminum with white epoxy
powder coat paint
• Wireless base stations
• Qty 7 engineered hole knockouts for
many possible configurations.
No drilling required!
• Direct burial equipment
• Qty 4 0.25” tall threaded standoffs and
mounting plate for mounting of electronics
inside enclosure
• Pole mount or wall mount
• IP67 rated for long term weatherproofing
• Fits common WiFi radio boards
Americas: +1.847 839.6907
IAS-AmericasEastSales@lairdtech.com
Europe: +44.1628.858941
IAS-EUSales@lairdtech.com
Asia: +86.21.5855.0827.127
IAS-AsiaSales@lairdtech.com
www.lairdtech.com
• Wireless client radios
• Repeater systems
• 802.11 a/b/g wireless systems
• Fiber-optic junction box
7x6x2 DCE
ANTENNA PATTERNS
2300-2700 MHz
H-Plane
2400-2500 MHz
E-Plane
H-Plane
E-Plane
H-Plane
3300-3800 MHz
H-Plane
E-Plane
5150-5850 MHz
E-Plane
VSWR GRAPHS
1.9 1.9
2.0 1.8
2.0
1.8
1.9
1.7 1.9
1.7
1.9 1.7
1.9
1.7
1.8
1.6 1.8
1.6
1.8 1.6
1.8
1.6
VSWR
VSWR
1.5 1.3
1.5
1.3
1.4 1.2
1.4
1.2
1.3
1.1 1.3
1.1
1.3 1.1
1.3
1.1
1.2
1.0 1.2
1.0
1.2 1.0
1.2
1.0
2.302.30 2.342.34 2.382.38 2.422.42 2.462.46 2.50 2.50 2.542.54 2.582.58 2.622.62 2.662.66 2.702.70
1.1 1.1
Frequency
Frequency
(GHz)(GHz)
1.0 1.0
2.
400
2.400
1.1 1.1
2.302.30 2.342.34 2.382.38 2.422.42 2.462.46 2.502.50 2.542.54 2.582.58 2.622.62 2.662.66 2.702.70
2.0 2.0
Frequency
Frequency
(GHz)(GHz)
2.400
2.400 2.410
2.410 2.420
2.420 2.430
2.430 2.440
2.440 2.450
2.450 2.460
2.460 2.470
2.470 2.480
2.480 2.490
2.490 2.500
2.500
2.0 2.0
Frequency
Frequency
(GHz)
(GHz)
1.9 1.9
1.9 1.9
3300-3800 MHz
2. 420
2.420
2.
430
2.430
1.9 1.9
1.7
1.7
1.9
1.9
1.7 1.7
1.8 1.8
1.6
1.6
1.8
1.8
1.6 1.6
2.
440
2.440
2. 450
2.450
2.
460
2.460
2.
470
2.470
2.
480
2.480
2.
490
2.490
2.
500
2.500
Frequency
Hz) (G (GHz)
Frequency
5150-5850 MHz
VSWR
2.0
2.0
1.8 1.8
VSWR
2.0 2.0
1.8
1.8
1.7 1.7
1.5
1.5
2.
410
2.410
1.0 1.0
1.7
1.7
1.5 1.5
1.5 1.5
1.3
1.3
VSWR
VSWR
1.6
1.6
1.4 1.4
VSWR
1.6 1.6
1.4
1.4
VSWR
1.6 1.4
1.6
1.4
1.4
1.2
1.2 1.4
VSWR
VSWR
1.5
1.3 1.5
1.3
1.7 1.5
1.7
1.5
VSWR
1.7
1.5
1.5 1.7
VSWR
VSWR
1.9 1.9
2.0
1.8
1.8 2.0
1.6
1.4 1.6
1.4
VSWR
2400-2500 MHz
2.0 2.0
VSWR
VSWR
2300-2700 MHz
2.0 2.0
1.5
1.5
1.3 1.3
1.4 1.4
1.2
1.2
1.4
1.4
1.2 1.2
1.3 1.3
1.1
1.1
1.3
1.3
1.1 1.1
1.2 1.2
1.0
1.0
1.2
1.2
1.0 1.0
3.300
3.300 3.350
3.350 3.400
3.400 3.450
3.450 3.500
3.500 3.550
3.550 3.600
3.600 3.650
3.650 3.700
3.700 3.750
3.750 3.800
3.800
1.1 1.1
Frequency
Frequency
(GHz)(GHz)
1.0 1.0
5.150
5.150 5.220
5.220 5.290
5.290 5.360
5.360 5.430
5.430 5.500
5.500 5.570
5.570 5.640
5.640 5.710
5.710 5.780
5.780 5.850
5.850
1.11.1
Frequency
Frequency
(GHz)(GHz)
1.0 1.0
3.300 3.350
3.350 3.400
3.400 3.450
3.450 3.500
3.500 3.550
3.550 3.600
3.600 3.650
3.650 3.700
3.700 3.750
3.750 3.800
3.800
3.300
Frequency
Frequency
(GHz)(GHz)
5.150
5.
150
5.220
5.
220
5.290
5.
290
5.360
5. 360
5.430
5.
430
5.500
5.
500
5.570
5.
570
Frequency
(GHz)
Frequency
Hz) (G
5.640
5. 640
5.710
5. 710
5.780
5.
780
5.850
5.
850
7x6x2 DCE
ications
Gain (integrated antenna)
VSWR (integrated antenna)
Impedance
Input Power
Wind Survivability
Weight (die-cast enclosure)
Dimensions (inside)
Dimensions (outside)
Radome
Operational Temperature
Mount Style
2300-2700
2400-2500
14 dBi
1.8:1
12 dBi
1.5:1
3300-3800
4940-5850
16 dBi
18 dBi
1.7:1
1.7:1
50 OHM
100 W
150 mph
40 oz (1.13kg)
7.125” x 6.125” x 2” (181 x 156 x 51mm) 10"
x 7.1"x 2.25" (254 x 180 x 57 mm)
2400-2485/
5150-5850
12 / 15 dBi
1.5:1
ASA
-30°C to +75°C
Wall / Mast / Tilt
Die Cast Enclosure (No Antenna)
Die Cast Enclosure w/ Hinged Die Cast Door (No Antenna)
Die Cast Enclosure w/ 2300-2700MHz, 14dBi Antenna Integrated Into
Hinged Door Die Cast Enclosure w/ 2400-2500MHz, 12dBi Antenna
Integrated Into Hinged Door Die Cast Enclosure w/ 3300-3800MHz, 16dBi
Antenna Integrated Into Hinged Door Die Cast Enclosure w/
4940-5850MHz, 19dBi Antenna Integrated Into Hinged Door Die Cast
Enclosure w/ Dual-Band 2400-2485MHz/5150-5850MHz,
12dBi/16dBi Antenna Integrated Into Hinged Door
(xxxx = connector type - MC, MMCX, RMMCX, RSMA, RTNC, SSMB, and UFL)
ACCESSORIES FOR DCE-7x6x2
Hinged Die Cast Door for DCE-7x6x2
Hinged ASA Door w/2300-2700MHz, 14dBi
Antenna Hinged ASA Door w/2400-2500MHz,
12dBi
Antenna
Hinged
ASA
Door
w/3300-3800MHz, 16dBi Antenna Hinged ASA
Door w/4940-5850MHz, 19dBi Antenna
Hinged ASA Door w/Dual-Band 2400-2485MHz/5150-5850MHz, 12dBi/16dBi Antenna
NOTES
• All shipments F.O.B. Schaumburg, IL 60173
www.lairdtech.com
ANT-DS-7x6x2-DCE 0115
Any information furnished by Laird Inc. and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use and application of Laird
materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness, merchantability or suitability of any Laird materials or
products for any specific or general uses. Laird shall not be liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Terms and Conditions of sale in
effect from time to time, a copy of which will be furnished upon request. © Copyright 2015 Laird Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other marks are trademarks or
registered trademarks of Laird Inc. or an affiliate company thereof. Other product or service names may be the property of third parties. Nothing herein provides a license under any Laird or any third
party intellectual property rights.
很抱歉,暂时无法提供与“DCE-7X6X2-NP”相匹配的价格&库存,您可以联系我们找货
