122.00
[4.80]
106.00
[4.17]
80.85
[3.18]
(INSIDE HEIGHT)
B
4.75
[.19]
104.00
[4.09]
(INSIDE
WIDTH)
B
90.20
[3.55]
TOP VIEW
25.00
[.98]
20.25
[.80]
110.11
[4.33]
120.00
[4.72]
A
A
4.43
[.17]
SECTION B-B
END VIEW
108.00
[4.25]
1.50
[.06]
86.00
[3.39]
95.00
[3.74]
11.00
[.43]
65.20
[2.57]
STEEL INNER PANEL
SOLD SEPERATLY
6.00
[.24]
UL
O
C
112.29
[4.42]
26.00
[1.02]
(INSIDE LENGTH)
23.00
[.91]
7.00
61.00
[2.40]
107.00
[4.21]
[.28]
Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.)
Contact Factory
mjm@hammondmfg.com for quotes
Solid models of this enclosure available in STEP or IGES.
(Part number and text placement/orientation on our products are subject to change,
we do not recommend using them as a locating reference for modification purposes)
SECTION A-A
SIDE VIEW
83.76
[3.30]
US LISTED
FILE #E65324
NEMA 4, 4X
NOTE
Purchased assembly includes Box, Lid, Gasket and 4 cover screws
Enclosure Molded from Glass Reinforced Polyester
113.27
[4.46]
106.76
[4.20]
Screw Should Not be Torqued Past 8-9.5 lbf.in (90-110 cN.m)
106.00
89.97 [4.17]
[3.54]
59.64
[2.35]
104.76
[4.12]
ACCEPTS
M6x1
SCREW
15.20
[.60]
82.00
[3.23]
65.97
110.11
[2.60]
[4.33]
10.21
[.40]
6.80
[.27]
PART NUMBERS
1590ZGRP121 Enclosure
Grey Enclosure
C
ACCESSORIES
Copper Ground Hardware (4 Pack)
[M6 - 1.0 X 6mm / M6 Washer]
1590ZGRP121GY
SCGM6GRP
Steel Inner Panel
1590ZGRP121PL
Hinge Kit (2 Pack)
1427HK
INSIDE LID
SECTION C-C
MOUNTING HOLE
C
ACCEPTS M6x1 SCREW
INSIDE BOX
Dimensions:
mm
[inches]
1590ZGRP121
www.hammondmfg.com
很抱歉,暂时无法提供与“1590ZGRP121”相匹配的价格&库存,您可以联系我们找货
