2
1
SECTION A-A
(Side View Inside Assembly)
Bottom View of Assembly
Front Face
A
n11.68
n 9.01
[.460]
(Top Bossn )
[.355]
(Bottom Boss n)
Detail View of Boss
(Located on Top and Bottom Cover)
3.10
[.122]
160.35
[6.313]
n 8.40
B
B
[.331]
Front Face
A
78.00
[3.071]
(Inner Box Height)
137.85
[5.427]
End View of Assembly
B
SECTION B-B
(Inside of Bottom Cover)
Top Cover
2.76
[.109]
(PCB dist from inner wall)
End Panel
158.65
[6.246]
.50
[.020]
(PCB dist from
end panel)
B
149.10
[5.870]
(Inner Box Width)
NOTE
Purchased Assembly includes top and bottom cover, front and end aluminum
panels (alloy 5052-H32, SPV coating on one side), 2 cover screws, and 4
rubber feet.
149.44
[5.883]
(Inner Box Length)
85.20
[3.354]
Front/Rear Panel
(Dashed Line Indicates Viewing Area)
145.55
[5.730]
(Viewing Area)
Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. )
Solid models of this enclosure available in STEP or IGES.
Contact Factory
mjm@hammondmfg.com
P.C. Board Aligned on Bosses
Maximum P.C. Board Size
27.38
[1.078]
67.92
[2.674]
12.60
[.496]
9.17
[.361]
A
77.00
[3.031]
(Viewing Area)
79.50
[3.130]
150.00
[5.906]
1.65
[.065]
143.58
[5.653] 88.83
[3.497]
29.75
[1.171]
P.C. Board
(Not Supplied)
n3.51 X 4
1598E Instrument Case
FLAME RETARDANT ABS (UL94-VO)
Black Enclosure w ith Alum inum Pa nels
1598EBK
Gre y Enclosure w ith Alum inum Pa ne ls
1598EGY
Black EMI/RFI Shielde d
1598REBK
NON-FLAME RETARDANT GPABS (UL94-HB)
1598ESGY
Grey Enclosure w ith Black Plastic Panels
1598ESGYPBK
ACCESSORIES
Bla ck Pla stic Pa ne ls
1598PLEBK
Rubber Fe et (Pkg 24)
1421T2
For 1598 FR-ABS
1591MS100
Cover Screws (Pk g 100) [M3 - 0.5 x 10mm]
For 1598 GPABS
1591TS100
Cover Screws (Pk g 100) [#4 x 5/8" (15.9mm)]
For Both Mode ls
1598ATS100
PCB Screws (Pk g 100) [#6 x 1/4" (6.4mm)]
[.138]
88.95
[3.502]
1598E
148.44
[5.844]
2
1
A
很抱歉,暂时无法提供与“1598REBK”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+415.052841+49.61980
- 5+389.080805+46.51483
- 10+363.1377910+43.41333
- 25+356.6527625+42.63804
- 50+350.1685750+41.86285
- 100+344.98183100+41.24277
- 250+337.20026250+40.31248
