1456PG4BKBU
1456PG4BKBU
    HAMMONDMANUFACTURING
    CONSOLE ALUM 14.18"L X 7.48"W
1456PG4BKBU 数据手册
8 7 28.58 mm [1.125 in] D 6 5 3 2 1 57.13 mm [2.249 in] 355.60 mm [14.000 in] A 101.60 mm [4.000 in] 28.39 mm [1.118 in] 72.21 mm [2.843 in] 3.18 mm [0.125 in] 6.35 mm [0.250 in] 356.11 mm [14.020 in] C 4 180.49 mm [7.106 in] 22.23 mm [0.875 in] 106.83 mm [4.206 in] m 3m ] 98.35 mm 5.9 45 in 4 1 .7 [3.872 in] [5 25.54 mm 30.0° [1.006 in] 31.92 mm [1.257 in] R2.44 mm 5X [0.096 in] D 155.17 mm [6.109 in] 61.19 mm [2.409 in] R4.76 mm [0.188 in] m 6m ] 8.3 in 14 5.841 [ C 30.0° DETAIL A ASSEMBLY - REAR VIEW (OPEN) n4.80 mm 4X 166.60 mm [6.559 in] [0.189 in] ASSEMBLY - SIDE VIEW (OPEN) 172.64 mm [6.797 in] 22.23 mm [0.875 in] 163.09 mm [6.421 in] 6.35 mm [0.250 in] 3.18 mm [0.125 in] 292.10 mm [11.500 in] B 334.98 mm [13.188 in] 190.09 mm [7.484 in] 172.62 mm [6.796 in] B 344.17 mm [13.550 in] 334.95 mm [13.187 in] B e ig e Top, B lue C as e - 1456P G 4W H B U B la ck Top, B lue C as e - 1456P G 4B K B U E nc los ure C as e - 12 ga. A lum inum Top P anel S iz es to 14" W ide - 14 ga. A lum inum S elf A dhes ive R ubber F eet Inc luded R eguired H ardw are Inc luded R eplac em ent S c rew s - 1421-J6 (6 pc s .) 360.22 mm [14.182 in] 30.89 mm [1.216 in] A n2.79 mm 8X 1456PG4 [0.110 in] ENCLOSURE CASE - BOTTOM VIEW TOP PANEL - BOTTOM VIEW 8 7 6 B 1456P G4 DETAIL B 25.40 mm [1.000 in] A [0.171 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 183.74 mm [7.234 in] 14.29 mm [0.563 in] n4.34 mm 4X 5 4 3 2 1
1456PG4BKBU 价格&库存
很抱歉,暂时无法提供与“1456PG4BKBU”相匹配的价格&库存,您可以联系我们找货
1456PG4BKBU
  • 1+498.036141+64.63600
  • 10+415.0591410+53.86710
  • 50+387.3711250+50.27370
库存:1
