1456PH3BKBU
1456PH3BKBU
    HAMMONDMANUFACTURING
    CONSOLE ALUM 14.18"L X 8.61"W
1456PH3BKBU 数据手册
8 7 5 46.81 mm [1.843 in] 3.18 mm [0.125 in] 34.23 mm [1.348 in] 6.35 mm [0.250 in] 22.23 mm [0.875 in] 358.17 mm [14.101 in] DETAIL A 81.43 mm [3.206 in] 31.12 mm [1.225 in] 209.07 mm [8.231 in] 2 1 R2.44 mm 5X [0.096 in] D 72.95 mm [2.872 in] 15.0° A 3 56.43 mm [2.222 in] m 25 m 160. 09 in] [6.3 76.20 mm [3.000 in] C 4 355.60 mm [14.000 in] 28.58 mm [1.125 in] D 6 183.74 mm [7.234 in] 60.30 mm [2.374 in] 1 mm 161.559 in] [6.3 R4.76 mm [0.188 in] 15.0° C 38.36 mm [1.510 in] ASSEMBLY - REAR VIEW (OPEN) n4.80 mm 4X [0.189 in] 195.17 mm [7.684 in] 3.18 mm [0.125 in] 201.22 mm [7.922 in] 22.23 mm [0.875 in] 218.67 mm [8.609 in] 6.35 mm [0.250 in] 191.67 mm [7.546 in] ASSEMBLY - SIDE VIEW (OPEN) 201.19 mm [7.921 in] n4.34 mm 4X [0.171 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. DETAIL B B B 334.95 mm [13.187 in] 344.17 mm [13.550 in] 25.43 mm [1.001 in] 292.10 mm [11.500 in] 212.32 mm [8.359 in] 14.29 mm [0.563 in] 334.98 mm [13.188 in] n2.79 mm 8X [0.110 in] A 25.40 mm [1.000 in] 360.22 mm [14.182 in] A 11.82 mm [0.466 in] TOP PANEL - BOTTOM VIEW 8 7 1456PH3 ENCLOSURE CASE - BOTTOM VIEW 6 B 1456P H3 B e ig e Top, B lue C as e - 1456P H 3W H B U B la ck Top, B lue C as e - 1456P H 3B K B U E nc los ure C as e - 12 ga. A lum inum Top P anel S iz es to 14" W ide - 14 ga. A lum inum S elf A dhes ive R ubber F eet Inc luded R eguired H ardw are Inc luded R eplac em ent S c rew s - 1421-J6 (6 pc s .) 5 4 3 2 1
1456PH3BKBU 价格&库存
很抱歉,暂时无法提供与“1456PH3BKBU”相匹配的价格&库存,您可以联系我们找货
1456PH3BKBU
  • 1+500.996501+65.02020
  • 10+417.4970810+54.18350
  • 50+389.7219950+50.57880
库存:2
