1554V2GY
1554V2GY
    HAMMONDMANUFACTURING
    BOX PLASTIC GRAY 9.45"L X 6.3"W
1554V2GY 数据手册
227.00 [8.94] 240.00 [9.45] 83.00 [3.27] (INSIDE HEIGHT) B 4.00 [.16] 147.00 [5.79] 160.00 [6.30] A 152.26 [5.99] 3.00 [.12] A 148.26 [5.84] (INSIDE WIDTH) B TOP VIEW SECTION B-B SIDE VIEW 90.00 [3.54] 20.00 [.79] 212.42 [8.36] POLYCARBONATE VERSION ONLY UL O C 2.59 [.10] 70.00 [2.76] 6.00 [.24] 232.26 [9.14] 154.88 [6.10] 107.37 [4.23] STEEL PANEL ORDER SEPARATELY 146.74 [5.78] P urc has ed as s em bly inc ludes box , lid, 4 c over s c rews , and preform ed s ilic one gas k et. G eneral P urpos e A B S vers ion is not UL approved. (M atl UL94 - HB ) P oly c arbonate vers ion is UL 508 approved. (M atl UL94 - 5V A @ 3m m ) 231.47 [9.11] R e comme nde d C ov e r scre w torque -- 2.5 lbf-in (30 cN -m) 1554 V 1554V Re g u la r En clo su re 215.88 [8.50] 231.00 [9.09] 4X 4.57 [4X .18] MOUNTING HOLES Ge ne ral P urpose  A BS RA L‐7035 P olycarbonate  RA L‐7035 212.00 [8.35] S teel Inner P anels S teel P anel / P .C. B oard M ac hine S c rew [M 3 x 8m m P lated] S teel P anel / P .C. B oard S elf Tapping S c rew [#6 X 1/4" (6.4m m ) P lated] Cover S c rews (P k g 4) [M 4 X 25m m S tainles s S teel] S ilic one P re-form ed G as k et B lac k (P k g 2) 112.00 [4.41] R7.50 [.30] INSIDE BOX 1554V 2GYCL 1554V 2GYSL ACCES S O RIES 69.25 [2.73] M3 BRASS INSERTS 1554V GY 1554V 2GY 1554V Cle a r / S m o ke L id En clo su re P olycarbonate  Box  / Cle ar P olycarbonate  Lid P olycarbonate  Box  / Sm oke  P olycarbon ate  Lid 150.86 [5.94] 216.00 [8.50] ACCEPTS #6 SELF-TAPPING SCREW Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. N OT E 234.88 [9.25] 127.00 [5.00] US LISTED (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) SECTION A-A SIDE VIEW 201.50 [7.93] 115.88 [4.56] [.75] 19.69 [.78] ® FILE #E65324 NEMA 4, 4X (INSIDE LENGTH) 227.00 [8.94] 138.50 [5.45] 19.05 M4 STAINLESS STEEL INSERTS 1554V P L 1591MM100 1598A TS100 SC1554V 1554V GA SKET INSIDE LID Dimensions: mm [inches] 1554V www.hammondmfg.com ®
1554V2GY 价格&库存
很抱歉,暂时无法提供与“1554V2GY”相匹配的价格&库存,您可以联系我们找货
1554V2GY
  • 1+451.935651+56.67360
  • 5+386.300135+48.44278
  • 10+361.0748510+45.27948
  • 25+330.2202225+41.41025
  • 50+324.8193350+40.73297
库存:130
