1458VA3
1458VA3
    HAMMONDMANUFACTURING
    BOX STEEL BLACK 4"L X 4"W
1458VA3 数据手册
8 7 6 5 4 3 2 1 101.60 mm [4.000 in] 60.33 mm [2.375 in] D D 19.05 mm [0.750 in] 38.10 mm [1.500 in] 99.16 mm [3.904 in] 5.16 mm [0.203 in] 72.95 mm [2.872 in] 2.95 mm 44.45 mm [1.750 in] [0.116 in] 73.20 mm [2.882 in] C C ASSEMBLY - END VIEW (OPEN) ASSEMBLY - SIDE VIEW (OPEN) Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 98.60 mm [3.882 in] 15.88 mm [0.625 in] B 66.85 mm [2.632 in] 4.85 mm [0.191 in] 76.38 mm [3.007 in] 1458A 3 101.60 mm [4.000 in] 12.62 mm [0.497 in] 11.11 mm [0.438 in] Top/Bottom - 18 ga. S teel P owder Coated B lac k RA L 9011 - 1458A3 P owder Coated Gulf B lue RA L 5021 - 1458A3B Front/Re a r P a ne ls - .064 A lum inum 1- B lack RA L 9011 1- Grey RA L 7032 8 S c rews S elf Tapping 632 P hilips Nic k el P lated 4 S elf A dhesive Rubber Feet Inc luded Replac em ent S c rews - 1421-J6 (6 pcs .) 7.94 mm [0.313 in] 2.95 mm [0.116 in] 15.88 mm [0.625 in] 101.60 mm [4.000 in] 70.66 mm [2.782 in] 5.54 mm 38.10 mm [1.500 in] B [0.218 in] 16.28 mm [0.641 in] A A 8 7 1458A3 TOP/BOTTOM ENCLOSURE END PLATES 6 5 4 hammondmfg.com 3 2 1
1458VA3 价格&库存
很抱歉,暂时无法提供与“1458VA3”相匹配的价格&库存,您可以联系我们找货
1458VA3
    • 1+544.129551+70.60036
    • 5+458.851745+59.53564
    • 10+426.6762910+55.36090
    • 25+387.7810825+50.31428
    • 50+371.1610350+48.15784
    库存:1
