1456RH3BKBU
1456RH3BKBU
    HAMMONDMANUFACTURING
    CONSOLE ALUM 17.12"L X 8.61"W
1456RH3BKBU 数据手册
8 7 6 5 6.35 mm [0.250 in] 3.18 mm [0.125 in] D 27.78 mm [1.094 in] 4 430.21 mm [16.938 in] 57.15 mm [2.250 in] 22.23 mm [0.875 in] 76.20 mm [3.000 in] DETAIL A A m 75 m 159. 89 in] [6.2 30.20 mm 15.0° [1.189 in] 46.81 mm [1.843 in] 34.13 mm [1.344 in] 430.71 mm [16.957 in] 2 1 R3.07 mm 5X [0.121 in] D 72.09 mm [2.838 in] 183.74 mm [7.234 in] 61.70 mm [2.429 in] 1 mm 161.559 in] [6.3 R6.35 mm [0.250 in] 81.43 mm [3.206 in] 212.32 mm [8.359 in] 3 R4.76 mm [0.188 in] 15.0° 38.36 mm [1.510 in] C ASSEMBLY - REAR VIEW (OPEN) C ASSEMBLY - SIDE VIEW (OPEN) 201.22 mm [7.922 in] n4.80 mm [0.189 in] 195.17 mm [7.684 in] 191.67 mm [7.546 in] 22.23 mm [0.875 in] DETAIL B 14.29 mm [0.563 in] B 418.78 mm [16.488 in] 218.67 mm [8.609 in] 3.18 mm [0.125 in] 6.35 mm [0.250 in] 201.19 mm [7.921 in] n4.34 mm 6X [0.171 in] B Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 212.32 mm [8.359 in] 100.01 mm [3.938 in] 366.71 mm [14.438 in] B 1456RH3 25.40 mm [1.000 in] 434.82 mm [17.119 in] 409.55 mm [16.124 in] 409.59 mm [16.126 in] B e ig e Top, B lue C as e - 1456R H 3W H B U B la ck Top, B lue C as e - 1456R H 3B K B U E nc los ure C as e - 12 ga. A lum inum Top P anel S iz es to 14" W ide - 14 ga. A lum inum S elf A dhes ive R ubber F eet Inc luded R eguired H ardw are Inc luded R eplac em ent S c rew s - 1421-J6 (6 pc s .) n2.79 mm 10X [0.110 in] 11.83 mm [0.466 in] A TOP PANEL - BOTTOM VIEW 8 7 A 1456RH3 ENCLOSURE CASE - BOTTOM VIEW 6 5 4 3 2 1
1456RH3BKBU 价格&库存
很抱歉,暂时无法提供与“1456RH3BKBU”相匹配的价格&库存,您可以联系我们找货
1456RH3BKBU
  • 1+596.861651+77.52930
  • 10+497.4282110+64.61340
  • 50+464.2837350+60.30810
库存:2
1456RH3BKBU
  • 1+613.848151+79.73576
  • 5+517.801525+67.25979
  • 10+481.5131110+62.54611
  • 25+437.6628225+56.85018
  • 50+425.1053450+55.21903
库存:1
