1457N1202E
1457N1202E
    HAMMONDMANUFACTURING
    BOX ALUM BLACK/NAT 5.24"LX4.25"W
1457N1202E 数据手册
8 7 6 5 151.00 mm [5.945 in] 139.00 mm [5.472 in] 116.00 mm [4.567 in] D 4 3 2 1 50.11 +- 0.00 0.18 mm [1.973 6.00 mm [0.236 in] K +0.000 - 0.007 ] in D 86.00 mm [3.386 in] 108.00 mm [4.252 in] 60.00 mm [2.362 in] 96.00 +- 0.00 0.18 mm 101.00 +- 0.00 0.18 mm [3.780 [3.976 +0.000 - 0.007 in ] +0.000 - 0.007 ] in C C L 4.25 mm [0.167 in] K 120.00 +- 0.54 0.50 mm [ 2.00 +- 0.00 0.18 mm SECTION K-K [0.079 ] 4.724 +- 0.02 0.02 in +0.000 - 0.007 in ] 1.50 mm [0.059 in] Inside Face to Face Dimension ASSEMBLY - VIEW FROM TOP .75mm (.030") Deep Recess For Labels/Keypads etc. DETAIL L B 108.00 mm [4.252 in] 96.02 mm [3.780 in] 58.54 mm [2.305 in] R5.99 mm 4X [0.236 in] 2.50 mm [0.098 in] n3.60 mm x 8.00 mm v 7.00 mm x 2.50 mm 4X 83.72 mm [3.296 in] n5.00 mm x 0.60 mm 4X 131.00 mm [5.157 in] 58.61 mm [2.308 in] 45.14 mm 54.37 mm [1.777 in] [2.141 in] PROTECTION TO IP 65 Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. N O TE P u rc h a s e d a s s e m b ly i n c l u d e s b o x , e n d p a n e l s , s t a i n l e s s s t e e l # 6 T a p t ig h t s c re w s , s e l f a d h e s i ve r u b b e r fe e t , g a s k e t s a n d O R in g s . B o x m a d e fro m E x t ru d e d A l u m i n u m 6 0 6 3 . E n d p a n e l s m a d e fro m T y p e 3 8 0 D i e c a s t A l u m i n u m w i t h a b l a c k p o w d e r p a in t fi n i s h . B W A TE R P R O O F 1 4 5 7 N 1 2 0 2 P AR T N UM B ERS C le a r a n o d iz e d b o x w it h b la c k p o w d e r 1457N 1202 p a in t e d e n d p a n e ls B la c k p o w d e r p a in t e d b o x a n d e n d 1457N1202B K p a n e ls E M I / R F I S H I E L D E D (I P 5 4 ) C le a r a n o d iz e d b o x w it h b la c k p o w d e r 1457N1202E p a in t e d e n d p a n e ls B la c k p o w d e r p a in t e d b o x a n d e n d 1457N 1202E B K p a n e ls A C C ES S O R IES S e e w e b s i t e fo r a c c e s s o ri e s . Fits 120mm (4.724") X 100mm (3.937") PCB Note: Aluminum extrusion has a tolerance of -/+ .02" A A 1457N1202 END PANEL - VIEW FROM OUTSIDE 8 7 6 5 4 3 2 1
1457N1202E 价格&库存
很抱歉,暂时无法提供与“1457N1202E”相匹配的价格&库存,您可以联系我们找货
1457N1202E
  • 1+558.775491+72.63901
  • 5+471.237155+61.25931
  • 10+438.1875610+56.96297
  • 25+398.2509425+51.77134
  • 50+382.2401550+49.68999
