1457N1602E
1457N1602E
    HAMMONDMANUFACTURING
    BOX ALUM BLACK/NAT 6.81"LX4.25"W
1457N1602E 数据手册
8 7 6 5 4 3 2 1 191.00 mm [7.520 in] 179.00 mm [7.047 in] 156.00 mm [6.142 in] D 50.11 +- 0.00 0.18 mm [1.973 +0.000 - 0.007 ] in D 6.00 mm [0.236 in] M 86.00 mm [3.386 in] 108.00 mm [4.252 in] 60.00 mm [2.362 in] 96.00 +- 0.00 0.18 mm 101.00 +- 0.00 0.18 mm [3.780 [3.976 +0.000 - 0.007 ] in +0.000 - 0.007 ] in C C N 4.25 mm [0.167 in] M [6.299 +0.02 - 0.02 PROTECTION TO IP 65 SECTION M-M 160.00 +- 0.54 0.50 mm ] 2.00 +- 0.00 0.18 mm in Inside Face to Face Dimension .75mm (.030") Deep Recess For Labels/Keypads etc. 1.50 mm [0.059 in] ASSEMBLY - VIEW FROM TOP [0.079 +0.000 - 0.007 ] in 2.50 mm [0.098 in] B 108.00 mm [4.252 in] 96.02 mm [3.780 in] 58.61 mm [2.308 in] A 58.61 mm [2.308 in] n5.00 mm x 0.60 mm 4X 7 6 N O TE P u rc h a s e d a s s e m b ly in c lu d e s b o x , e n d p a n e ls , s t a in le s s s t e e l # 6 T a p t ig h t s c re w s , s e lf a d h e s ive ru b b e r fe e t , g a s k e t s a n d O R in g s . B o x m a d e fro m E x t ru d e d A lu m in u m 6 0 6 3 . E n d p a n e ls m a d e fro m T y p e 3 8 0 D ie c a s t A lu m in u m w it h a b la c k p o w d e r p a in t fin is h . B W A TE R P R O O F 1 4 5 7 N 1 6 0 2 P AR T N UM B ERS C le a r a n o d iz e d b o x w it h b la c k p o w d e r 1457N 1602 p a in t e d e n d p a n e ls B la c k p o w d e r p a in t e d b o x a n d e n d 1457N1602B K p a n e ls E M I / R F I S H I E L D E D (I P 5 4 ) C le a r a n o d iz e d b o x w it h b la c k p o w d e r 1457N1602E p a in t e d e n d p a n e ls B la c k p o w d e r p a in t e d b o x a n d e n d 1457N 1602E B K p a n e ls A C C ES S O R IES S e e w e b s it e fo r a c c e s s o rie s . A n3.60 mm x 8.00 mm v 7.00 x 2.50 mm 4X 8 R5.99 mm 4X [0.236 in] 45.14 mm [1.777 in] 54.33 mm [2.139 in] 171.00 mm [6.732 in] Fits 160mm (6.299") X 100mm (3.937") PCB Note: Aluminum extrusion has a tolerance of -/+ .02" DETAIL N Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 5 1457N1602 END PANEL - VIEW FROM OUTSIDE 4 3 2 1
1457N1602E 价格&库存
很抱歉,暂时无法提供与“1457N1602E”相匹配的价格&库存,您可以联系我们找货
1457N1602E
  • 1+492.637851+63.93540
  • 10+443.3566510+57.53960
  • 50+394.1625250+51.15510
