1456RK4BKBU
1456RK4BKBU
    HAMMONDMANUFACTURING
    CONSOLE ALUM 17.12"L X 10.48"W
1456RK4BKBU 数据手册
8 7 D 6 4 A 72.21 mm [2.843 in] m 8m ] 5.8 in 14 5.743 [ 30.0° DETAIL A 28.34 mm [1.116 in] 430.71 mm [16.957 in] C 106.83 mm [4.206 in] R6.35 mm [0.250 in] ASSEMBLY - REAR VIEW (OPEN) 242.80 mm [9.559 in] n4.80 mm 4X [0.189 in] 248.84 mm [9.797 in] 31.92 mm [1.257 in] 22.23 mm [0.875 in] 239.29 mm [9.421 in] 3.18 mm [0.125 in] 6.35 mm [0.250 in] 418.78 mm [16.488 in] 24.74 mm [0.974 in] 97.49 mm [3.838 in] 231.37 mm [9.109 in] 257.89 mm [10.153 in] 137.39 mm [5.409 in] R4.76 mm [0.188 in] m 6m ] 8.3 in 14 5.841 [ 30.0° C ASSEMBLY - SIDE VIEW (OPEN) 248.82 mm [9.796 in] 266.29 mm [10.484 in] n4.34 mm 6X [0.171 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. B q 409.55 mm [16.124 in] q 409.59 mm [16.126 in] 14.29 mm [0.563 in] B 1456RK 4 259.94 mm [10.234 in] 366.71 mm [14.438 in] 1 R3.07 mm 5X [0.121 in] DETAIL B B 2 D 133.32 mm [5.249 in] 22.23 mm [0.875 in] 101.60 mm [4.000 in] 3 6.35 mm [0.250 in] 3.18 mm [0.125 in] 430.21 mm [16.938 in] 27.78 mm [1.094 in] 5 B e ig e Top, B lue C as e - 1456R K 4W H B U B la ck Top, B lue C as e - 1456R K 4B K B U E nc los ure C as e - 12 ga. A lum inum Top P anel S iz es to 14" W ide - 14 ga. A lum inum S elf A dhes ive R ubber F eet Inc luded R eguired H ardw are Inc luded R eplac em ent S c rew s - 1421-J6 (6 pc s .) 25.40 mm [1.000 in] 434.82 mm [17.119 in] n2.79 mm 10X [0.110 in] 30.09 mm [1.185 in] A 7 1456RK4 ENCLOSURE CASE - BOTTOM VIEW TOP PANEL - BOTTOM VIEW 8 A 6 5 4 3 2 1
1456RK4BKBU 价格&库存
很抱歉,暂时无法提供与“1456RK4BKBU”相匹配的价格&库存,您可以联系我们找货
1456RK4BKBU
    • 1+474.93346
    库存:1
