1457N1601EBK
1457N1601EBK
    HAMMONDMANUFACTURING
    BOX ALUM BLACK 6.81"L X 4.25"W
1457N1601EBK 数据手册
8 7 6 5 4 171.00 mm [6.732 in] 156.00 mm [6.142 in] 2 1 50.11 +- 0.00 0.18 mm [1.973 Z D 3 +0.000 - 0.007 ] in D 6.00 mm [0.236 in] 108.00 mm [4.252 in] 86.00 mm [3.386 in] 96.00 +- 0.00 0.18 mm 101.00 +- 0.00 0.18 mm [ [3.976 3.780 +- 0.000 0.007 in ] +0.000 - 0.007 ] in C C AA 4.25 mm [0.167 in] Z 160.00 +- 0.54 0.50 mm [6.299 +0.02 - 0.02 in SECTION Z-Z ] PROTECTION TO IP 65 2.00 +- 0.00 0.18 mm [0.079 +0.000 - 0.007 in ] 1.50 mm [0.059 in] Inside Face to Face Dimension ASSEMBLY - VIEW FROM TOP .75mm (.030") Deep Recess For Labels/Keypads etc. 2.50 mm [0.098 in] B 58.61 mm [2.308 in] 54.61 mm [2.150 in] Fits 160mm (6.299") X 100mm (3.937") PCB Note: Aluminum extrusion has a tolerance of +/- .02" 108.00 mm [4.252 in] 96.02 mm [3.780 in] 83.72 mm [3.296 in] DETAIL AA R5.99 mm 4X [0.236 in] 54.42 mm [2.142 in] 58.61 mm 45.14 mm [2.308 in] [1.777 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. N O TE P u rc ha s e d a s s em b ly in c lu d e s b o x , en d p an e ls , s t a inle s s s t e e l # 6 Ta p t ig h t s c re w s , s e lf a d he s ive rub b e r fe e t , g as k e t s a n d O R in gs . B o x m a d e fro m E x t ru de d A lu m in u m 6 0 6 3. E n d pa n e ls m a de fro m Ty p e 3 8 0 D iec a s t A lum in um w it h a b la c k po w d e r p ain t fin is h. W A TE R P R O O F 1 4 57 N 1 6 0 1 P A R T N U M B ER S C le ar a n o diz e d b o x w it h b la c k p o w d er 1 45 7 N 1 6 0 1 pa in t ed e n d p a n els B la c k po w d e r p ain t e d b o x an d e nd 14 5 7 N 1 6 01 B K pa n e ls EM I / R F I S H I EL D ED (I P 5 4 ) C le ar a n o diz e d b o x w it h b la c k p o w d er 1 45 7 N 1 6 0 1E pa in t ed e n d p a n els B la c k po w d e r p ain t e d b o x an d e nd 14 5 7 N 1 6 01 E B K pa n e ls A C C ES S O R I ES S e e w e b s it e for a c c es s o rie s . A B A n3.60 mm x 8.00 mm v 7.00 mm x 2.50 mm 4X n5.00 mm x 0.60 mm 4X 8 7 6 1457N1601 END PANEL - VIEW FROM OUTSIDE 5 4 3 2 1
1457N1601EBK 价格&库存
很抱歉,暂时无法提供与“1457N1601EBK”相匹配的价格&库存,您可以联系我们找货
