1590Z119GY
1590Z119GY
    HAMMONDMANUFACTURING
    Box Metal, Aluminum Gray Cover Included 4.802" L x 4.739" W (121.97mm x 120.37mm) X 3.272" (83.11mm)
1590Z119GY 数据手册
104.00 [4.09] 73.35 [2.89] 119.99 [4.72] (INSIDE DEPTH) A 10.00 [.39] 106.02 [4.17] 121.99 [4.80] B B 110.86 86.53 [4.36] [3.41] INSIDE WIDTH A TOP VIEW 20.60 [.81] SECTION A-A END VIEW 2.00 [.08] 63.70 [2.51] 4.75 [.19] (AVERAGE WALL THICKNESS) 82.10 [3.23] 110.56 [4.35] DRAWINGS AVALIBLE FOR STEEL INNER PANEL 65.56 [2.58] 106.00 [4.17] SECTION B-B SIDE VIEW 96.00 [3.78] 17.57 [.69] ACCEPTS M6 MACHINE GROUND SCREW Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 112.56 [4.43] 89.56 [3.53] (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) NOTE Purchased assembly includes box, lid, silicone gasket, 4 cover screws and 4 ground screws with washers. Box and lid are made from Diecast Aluminum Alloy. C C 106.70 [4.20] 61.70 [2.43] ACCEPTS M6 - 1 MACHINE SCREW 26.00 [1.02] 82.00 [3.23] Recommended cover screw Torque 15-17 lbf.in ( 150 -170 cN.m) 1590Z119 1590Z119 Enclosure INSIDE BOX Basic Enclosure Black Enclosure Grey Enclosure - RAL7001 Gloss 17.70 [.70] 107.70 [4.24] 104.00 [4.09] INSIDE LID 5.60 [.22] 1590Z119 1590Z119BK 1590Z119GY ACCESSORIES 84.70 [3.33] 106.00 [4.17] US LISTED ® FILE #E65324 NEMA 4, 4X 108.53 [4.27] (INSIDE LENGTH) UL O C 6.47 [.25] SECTION C-C MOUNTING HOLE Steel Inner Panel 1590Z119PL Pre-Formed Silicone Gasket Copper Ground Hardware (4 Pack) [M6 - 1.0 X 10mm / M6 Washer] 1590Z119G 10.03 [.39] SCGM6 ® Dimensions: mm [inches] 1590Z119 www.hammondmfg.com
1590Z119GY 价格&库存
很抱歉,暂时无法提供与“1590Z119GY”相匹配的价格&库存,您可以联系我们找货
