1456WH3WHBU
1456WH3WHBU
    HAMMONDMANUFACTURING
    CONSOLE ALUM 20.26"L X 8.61"W
1456WH3WHBU 数据手册
8 7 6 5 4 6.35 mm [0.250 in] 29.57 mm [1.164 in] D 3.18 mm [0.125 in] 509.98 mm [20.078 in] 22.23 mm [0.875 in] 76.20 mm [3.000 in] A 46.81 mm [1.843 in] 510.49 mm [20.098 in] R6.35 mm [0.250 in] 81.43 mm [3.206 in] ASSEMBLY - REAR VIEW (OPEN) n4.80 mm 4X 195.17 mm [7.684 in] [0.189 in] 38.36 mm [1.510 in] 201.22 mm [7.922 in] 191.67 mm [7.546 in] 208.20 mm [8.197 in] D 183.74 mm [7.234 in] m 51 m 161. 59 in] [6.3 15.0° 61.70 mm [2.429 in] R4.76 mm [0.188 in] ASSEMBLY - SIDE VIEW (OPEN) 218.67 mm [8.609 in] 201.19 mm [7.921 in] C n4.34 mm 6X [0.171 in] [0.110 in] 3.18 mm [0.125 in] 446.48 mm [17.578 in] B 25.40 mm [1.000 in] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc. ) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. 6.35 mm [0.250 in] B DETAIL B B e ig e Top, B lue C as e - 1456W H 3W H B U B la ck Top, B lue C as e - 1456W H 3B K B U E nc los ure C as e - 12 ga. A lum inum Top P anel S iz es to 14" W ide - 14 ga. A lum inum S elf A dhes ive R ubber F eet Inc luded (4 pc s .) R equired H ardw are Inc luded R eplac em ent S c rew s - 1421-J6 (6 pc s .) 179.78 mm [7.078 in] 498.55 mm [19.628 in] 514.60 mm [20.260 in] 489.33 mm [19.265 in] 11.84 mm [0.466 in] A 7 A 1456WH3 ENCLOSURE CASE - BOTTOM VIEW TOP PANEL - BOTTOM VIEW 8 B 1456W H3 q 489.36 mm [19.266 in] 1 R3.07 mm 5X [0.121 in] m 15 m 160. 05 in] .3 6 [ 30.20 mm 15.0° [1.189 in] 72.09 mm [2.838 in] n2.79 mm10X 22.23 mm [0.875 in] q 2 57.15 mm [2.250 in] DETAIL A 34.13 mm [1.344 in] C 3 6 5 4 3 2 1
1456WH3WHBU 价格&库存
很抱歉,暂时无法提供与“1456WH3WHBU”相匹配的价格&库存,您可以联系我们找货
