1590Z140GY
1590Z140GY
    HAMMONDMANUFACTURING
    BOX ALUM GRAY 9.85"L X 3.13"W
1590Z140GY 数据手册
250.20 [9.85] A 3.28 [.13] 50.92 [2.00] 237.50 [9.35] (AVERAGE WALL THICKNESS) (INSIDE DEPTH) B B 68.00 [2.68] 71.65 [2.82] 79.80 [3.14] (INSIDE WIDTH) A 56.90 [2.24] TOP VIEW 15.00 [.59] SECTION A-A END VIEW 1.40 [.06] 6.25 [.25] 222.05 [8.74] 239.00 [9.41] 43.30 [1.70] 222.54 [8.76] 241.87 [9.52] (INSIDE LENGTH) 69.20 44.59 [2.72] [1.76] SECTION B-B SIDE VIEW 68.00 [2.68] Enclosures can be Factory Modified ( Milling, Drilling, Printing etc.) Contact Factory mjm@hammondmfg.com for quotes Solid models of this enclosure available in STEP or IGES. (Part number and text placement/orientation on our products are subject to change, we do not recommend using them as a locating reference for modification purposes) 3.52 237.50 [9.35] [.14] NOTE Purchased assembly includes box, lid, silicone gasket, 4 cover screws and 4 ground screws with washers. Box and lid are made from Diecast Aluminum Alloy. INSIDE LID Recommended cover screw Torque 5-7.5 lbf.in ( 50 -75 cN.m) 241.87 [9.52] 224.86 [8.85] 23.50 [.93] 13.97 52.00 [.55] [2.05] 15.30 [.60] 1590Z140 C DRAWINGS AVALIBLE FOR STEEL INNER PANEL INSIDE BOX Basic Enclosure Black Enclosure Grey Enclosure - RAL7001 Gloss 238.20 [9.38] ACCEPTS M4 MACHINE GROUND SCREW 1590Z140 Enclosure 10.10 [.40] 1590Z140 1590Z140BK 1590Z140GY ACCESSORIES 47.17 71.65 [1.86] [2.82] C ACCEPTS M4 - 0.7 MACHINE SCREW 7.46 4.35 [.29] [.17] Steel Inner Panel 1590Z140PL Pre-Formed Silicone Gasket Copper Ground Hardware (2 Pack) [M4 - 0.7 X 6mm / M4 Washer] 1590Z140G SECTION C-C MOUNTING HOLE Dimensions: mm [inches] SCGM4 ® 1590Z140 www.hammondmfg.com
1590Z140GY 价格&库存
很抱歉,暂时无法提供与“1590Z140GY”相匹配的价格&库存,您可以联系我们找货
